ASP pulley worth it?
Old Jan 5, 2004 | 09:17 PM
00silverz28's Avatar
Default ASP pulley worth it?
Are the ASP underdrive pulleys really worth the money? I'm saving for a cam package and ls6 intake now but I'd also like to get all the bolt on's.
I'm also trying to decide on which TB to get. Thanks.
Steve
Old Jan 5, 2004 | 09:25 PM
jrp's Avatar
jrp
SN95 Director
yes its worth it, its gains are more seen at the track then at the dyno.
Old Jan 5, 2004 | 09:35 PM
Damian's Avatar
LSX Mechanic
As JRP said, the Asp is most certainly worth it. It's an EASY 1-2 tenths and 1-2 mph.
As for the TB, my best choice has been Brett Bauer. I have his TB on my heads/cam car. #'s in sig...
josh
Old Jan 5, 2004 | 10:43 PM
Mike K.'s Avatar
Like the others said it is worth it get one.
Old Jan 6, 2004 | 01:18 AM
SouthFL.02.SS's Avatar
!LS1 11 Second Club
If you're doing a cam swap, it's (pulley) a free mod in terms of labor. Do it then.
If you have the $$$, the MTI Billet TB looks pimpin'.
Old Jan 6, 2004 | 12:08 PM
crainholio's Avatar
I just pulled an aftermarket pulley off the '01 LS1 I'm swapping into my project car. Not sure what brand, but it's aluminum and has a tiny accessory pulley diameter compared to the ATI 10% underdrive balancer I installed.
I'll post it in the For Sale section...no dings or dents I see, removed with a professional 3-bolt puller, I do road-course racing and really like ATI balancers.
Old Jan 6, 2004 | 12:33 PM
XLR8VRL's Avatar
I would take a look at FluidDamper and March has a viscous fluid damper also. SLP has a new one coming out too that has raised sides to help eliminate belt throwing probs. Good luck - Im having a hard time deciding!
I like the fluid type though - some people have had probs with some of the pulleys setting off the knock sensors.
Old Jan 6, 2004 | 06:44 PM
Damian's Avatar
LSX Mechanic
I have never heard of this. The only way I could see that possible is if the pulley was installed incorrectly causing it to wobble badly enough to set something off. I've installed about 25 ASP pulley's over the years and never experienced this..
Josh
Old Jan 6, 2004 | 06:49 PM
Venkman's Avatar
Ive heard of a few cases of this. Unknown whether the pulleys were defective or the installation was wrong.
Old Jan 6, 2004 | 09:57 PM
ClaySS01's Avatar
who sells ATI balancers?. or where to get them?
Old Jan 7, 2004 | 12:48 AM
jrp's Avatar
jrp
SN95 Director
you do know that those little icons pictures on the right hand side indicate sponsors in which you can buy things.
Old Jan 7, 2004 | 12:34 PM
ClaySS01's Avatar
sorry jrp , just askin. have looked ,all i see is the asp pulley. but thanks anyway
Old Jan 7, 2004 | 12:38 PM
HOTROD98Z's Avatar
www.Thunderracing.com
Old Jan 8, 2004 | 01:30 AM
2002SilverWS-6's Avatar
Josh
I just got a new pulley from ASP last week because the one I got it June some how got defected. I could not rev my motor past 4700 rpm"s without setting misfire codes. I changed plugs,wires,coil packs,pushrods,complete fuel rail with injectors, and swapped out pcm's. The last resort was putting my stock pulley back on and that fixed my misfire problem. ASP sent me a brand new pulley because they determined that the first pulley was defective being out of balance( of course free of charge). so it is possible to get a bad pulley because it happened to me.
Old Jan 8, 2004 | 06:40 AM
crainholio's Avatar
I got my ATI balancer from Thunder Racing. ATI pieces have a great reputation in racing, and the gen-3 engine specifically in the ASA series where they use LS1 crate engines. Katech uses them on their 7.0L engines for the C5R also.
The harmonic data I saw didn't really make a solid case by itself, the ATI doesn't really shine over the fluid type dampers until well over 6K rpm and I don't spend much time there when I'm on a road course. What did make the case was the ASA/Katech useage above, and the 2-piece design...you can heat up the hub and slide it right on, then bolt the damper to it. 16mm balancer installers aren't very available (yet).
