What's the consensus on intake manifold styles?
Old Jun 20, 2010 | 12:12 AM
gta3uzi's Avatar
Default What's the consensus on intake manifold styles?
I'm trying to figure out which way would be the best to go on intake manifold style for my street '00 Z.
A traditional 90/90 setup
or
A single plane EFI setup (small cowls are an option)
I'll be doing my own independent research, but if anybody else has done any and would like to share I would greatly appreciate it
Old Jun 20, 2010 | 12:16 AM
bww3588's Avatar
if your going to do a single plane EFI, the best way to go is a 4150 TB.
that being said, both will net you about the same, however, if your sticking with a 90/90, the 4150 will give you more room to grow.
Old Jun 20, 2010 | 12:24 AM
gta3uzi's Avatar
I was thinking about using an elbow. I'm not sure if it's possible to put an air filter on a 4150 from the looks of it.
Old Jun 20, 2010 | 12:49 AM
bww3588's Avatar
sure there is....
https://ls1tech.com/forums/12670823-post6.html
Old Jun 20, 2010 | 07:18 AM
SweetS10V8's Avatar
Telling us your engine is a "Street" engine isn't nearly enough info to be able to help you. Give us a rundown of what a "Street" engine is.
The general consensus is that elbows on these car KILL power, so stick with the 4150 style throttle body or the traditional plastic manifold and use a FAST 102mm.
Old Jun 20, 2010 | 11:01 AM
MonmouthCtyLS7's Avatar
Id stick w/ the Traditional setup
Old Jun 20, 2010 | 08:11 PM
gta3uzi's Avatar
For now It's just going to be a bolt on vehicle with the factory LS1. Nothing fancy. Looking for a setup that will play the nicest with a heads / cam job when that time comes.
So the consensus is - stick with a 90 or 102mm setup and avoid a single plane / elbow setup because the elbow kills the power.
Old Jun 20, 2010 | 08:18 PM
bww3588's Avatar
yes the elbow does kill power, but thats why you go with a 4150 style TB.
Old Jun 20, 2010 | 08:24 PM
gta3uzi's Avatar
That link you posted... Did the guy get to keep both of his windshield wipers?
Old Jun 20, 2010 | 08:26 PM
bww3588's Avatar
yes, it can be done, just takes some careful triming and attention to detail to seal it. not a big problem for how well the 4150 performs.
Old Jun 20, 2010 | 08:35 PM
gta3uzi's Avatar
Do you have any suggestions on which carb hat to use with the 4150?
The help and links have been greatly appreciated.
Old Jun 20, 2010 | 08:45 PM
bww3588's Avatar
Spectre
Old Jun 20, 2010 | 09:04 PM
Bird-Of-Prey's Avatar
I went from a stock setup with bolt-ons to a BBK intake and 80mm TB. I noticed a slight loss in bottom end (still smoke em for 100yrds) but a good improvement in the mid range and top end.. Then went to a Victor Jr. Aarons elbow and a FAST 90mm TB and had no loss anywhere except an increase in top end. To each his own. Different setups will produce different results.
Old Jun 20, 2010 | 10:23 PM
SweetS10V8's Avatar
Is there an echo?
