Cutting out Catalytic Converters
However, he said if I had a performance muffler, that my exhaust, post catalytic converter removal, would be somewhat louder and that I would hear a deceleration popping. I don't think I would like this popping noise he is talking about. At this point, my only options are to either have them cut out or pay to have the converter replaced, which is more expensive. I can't afford a new exhaust system (e.g. Borla).
I'm curious if anyone has any experience or knowledge on this subject. Thanks.
https://ls1tech.com/forums/generatio...converter.html
are a straight bolt-in, and keep your intact cats for
just-in-case. Or an annual drive to the inspection
station.
For the price of a long drill bit, a mini prybar and an
hour, you can bust out the bricks. The gutted shell
will be a bit "boomy" around 2KRPM but no rasp if you
dress some of the sharps you will find at the inlet
with a ball stone / burr and die grinder (or drill). This
will stand up to casual undercar inspection though
a smart trooper with infrared could notice its non-
functionality (It musta got old and blown out, yer
Honor!).
Check your local car club scene for someone who'll
kill the codes for beer.
Decel popping depends on tune more than pipe.
If you went for some kind of obnoxious exhaust like
a Loudmouth, yeah, catless will add to the obnoxious.
One with a real muffler, not so much.
http://www.summitracing.com/parts/WLK-88028/
OR save for some LTs and new ORY and a Frost mail tune, will be worth it in the long run.
Then I cut the flanges off the cats, measured the angle of the bends to go from stock manifolds to an edelbrock ORY. Two pieces of bent 3" pipe cost $20, I welded the flanges on.
With a stock muffler it had a very noticable increase in off idle torque but sounded like ****.
Went with pacesetter headers, sounds better, the low end torque was less.
Later I did the rest of the exhaust.
http://www.ws6project.com/user_stor/...oducts_id=2460
or another option:
http://www.ws6project.com/user_stor/...oducts_id=1099
