Kooks released new exhaust for f-body
Old 01-17-2011, 04:08 PM
  #361
ponyeater01LS1's Avatar
Originally Posted by disc0monkey
yeeeeeerp
why spend close to a grand on a corsa or gmmg when its the same as a $300 magnaflow, this system is an actual upgrade.
i agree now since I went from 11.65 to 11.30 flat and i prolly could have gotten quicker if i let it cool down and made another pass, next task is to get it on the dyno to see what my increase in numbers are
Old 01-19-2011, 03:39 PM
  #362
libertyforall1776's Avatar
Question
Does this exhaust clear the the Fays2 Watts Link? How about clearing a Strano Adjustable rear sway-bar?
Old 01-19-2011, 08:38 PM
  #363
Question
Please post some more pics of the over the axle area, between differential and exhaust, panhard bar and sway bar areas in relation to this exhaust -- I'm trying to see how well a Watts Link and Strano Adjustable Sway Bar would work with this setup...
THANKS!
Originally Posted by ponyeater01LS1
ground clearance is awesome
[IMG][/IMG]
Old 01-20-2011, 01:47 PM
  #364
WS6sleeper's Avatar
^check the kooks video on YouTube they have some good close ups that you can probably have the best view of how it passes over the axle.
Old 01-20-2011, 08:16 PM
  #365
Ill get some more day light pics tomorrow up and over the axle from all diff angles and hope that helps out and ill also do it with a tape measure so you all can see what the exact measurements need to be up and over and clearance needs to be. Im sure as long as you have the 2 stock panhard bars removed and replaced with after market stuff it will work most likely.
Old 01-25-2011, 03:55 PM
  #366
Lightbulb
Kooks finally put this unit on their website:
http://www.kookscustomheaders.com/show.php?pid=929
Also, I got a copy of their documentation that comes with this system -- pretty sparse. FYI, the text is copy & pasted below:
" 1998-2002 LS-1 Kooks Dual Exhaust
Installation Instructions
Thank you for your purchase, we appreciate your business.
Do not attempt this installation if proper safety equipment isn’t available to you. Seek the assistance of a professional installer. Read and understand all directions before starting any of the instruction process.
A life is highly recommended in the installation process of these components. If a vehicle lift in not accessible to you, a jack and four jack stands may be substituted. It is recommended to refer to your owner’s manual before raising and supporting any vehicle. A basic understanding of general hand tools and vehicle mechanics is also recommended/required.
Kooks LS1 Dual Exhaust requires the installation of Kooks LS1 headers, BMR drive shaft loop, Part #DSL001 and BMR drop panhard (trackbar), Part #PHR004, relocation brace. Kooks LS1 dual exhaust X-Pipe is a direct replacement for Kooks LS1 Y-Pipe.
After installing Kooks LS1 headers and removing original exhaust, proceed with the following steps on dual exhaust installation.
Install BMR drive shaft loop (Refer to BMR install instructions regarding any additional questions.)
-Remove existing support brace. (13mm bolts)
-Mark drive shaft to yoke position.
(It is recommended to reinstall drive shaft in the originally locked position.)
-Remove 7/16 bolts connecting drive shaft to the rear end yoke.
-Lover rear of drive shaft and slide BMR drive shaft loop over drive shaft,
-Re-install drive shaft and tighten bolts to factory specs.
Kooks Custom Headers – 141 Advantage Place. Statesville, NC 28677
1of 2
Install BMR drop panhard support bar.
Refer to BMR install instructions regarding any additional questions,
-Remove original panhard bar and panhard support brace.
-Remove rear factory heat shields and replace with Kooks supplied hear wrap.
-Install BMR drop panhard support brace.
-Re-install original panhard bar or replace with adjustable aftermarket panhard bar if desired.
Install Kooks rear exhaust hangers
-Remove factory hangers and replace with Kooks factory replacement hangers.
-Also supplied are two additional hangers to be mounted off rear bumper support studs located to the inside of the each frame rail. Additional hangers are to aid in support and eliminate exhaust from sagging over time.
Install Kooks Exhaust System
*Note* Do Not tighten clamps or hangers until entire exhaust has been installed.
Align exhaust and tighten
*Note* If exhaust has clearance issues and check for proper alignment and
installation.
If additional assistance is needed, please contact Kooks Custom Headers
Toll free at 866 586 KOOK or contact your dealer.
2 of 2
Old 01-25-2011, 04:12 PM
  #367
SSCAMARO02LS1's Avatar
yeeeeeerp
Now we all know that Kooks puts out a superior product...
If you really think that Corsa is even close in comparison to Magnaflow then you need to do a little more research there monkey.....
( and I am not bashing Magnaflow, its good for the price )
Nice set-up ponyeater
Old 01-26-2011, 01:39 AM
  #368
moneypit00's Avatar
Did you get that crooked left tip to straighten out? I'm having a hell of a time with mine. Been on stands for nearly 2 weeks now. I'd like to see someone install the over axle pipe without a lift. I couldn't do it.
Old 01-26-2011, 03:09 PM
  #369
yea my left one was crooked at first but i loosed all the clamps up again and start tweekin again and got everything straight and fittin right and I also did mine on jack stands and only had it about at most a foot off the ground as you can see in my vid a few posts back.
Old 01-26-2011, 08:44 PM
  #370
WS6RED2002TA's Avatar
I have see a few people on here complaining about Corsa muffler falling apart.(the internals).... Get looking exhaust system O.P. Im thinking about changing my exhaust system now.
Old 01-31-2011, 12:30 PM
  #371
PONTIAC SLP's Avatar
hey ponyeater01LS1 how do u like your kooks setup ? , do u have in car video so that i can hear it inside ? it's load enough ?
Old 01-31-2011, 12:53 PM
  #372
LS1rob00's Avatar
I want this, when I save up enough money the shitty Hooker catback is going bye bye
Old 01-31-2011, 03:01 PM
  #373
no in car vids but I had a SLP LM before and it was ungodly too loud this Kooks is well "perfect" put it this way I can now actually listen to my radio in the car now unlike before with the loudmouth system. The Kooks is a more deeper meaner sound BUT! when you stomp on it get the *** out the the way because it means buisness
Old 01-31-2011, 03:04 PM
  #374
oh and I also have my complete interior ripped out so as far as comparing loudness interior wise I cant really say now but before the interior was tore out yes it was awesome
Old 01-31-2011, 03:07 PM
  #375
thanks bro , i ordered the same hope will ship with my parts this week , i'll run it with my LSX454 CR 12:01
Old 01-31-2011, 04:00 PM
  #376
BrawlyZ28Camaro's Avatar
So your Z28 is slow huh? lol
Old 01-31-2011, 04:37 PM
  #377
BadROC's Avatar
I havn't seen anybody bring up lowered cars? Looks like plenty of clearance on ponyeaters car. Very interested in this setup but my car will be lowered with Strano springs. Ponyeater do you see me having an issue? Thanks
Old 01-31-2011, 05:00 PM
  #378
Lightbulb
Might want to phone Strano -- he already commented on a related topic:
https://ls1tech.com/forums/14415082-post41.html
Old 02-01-2011, 02:03 PM
  #379
okay so this is a picture for mine inside the box
Old 02-02-2011, 04:58 AM
  #380
BadROC's Avatar
Thanks for the reply I missed that post. He has a very good point.
Quick Reply: Kooks released new exhaust for f-body
