Kooks released new exhaust for f-body
#811
#813
its the age of them at this point...I picked up an 01 NBM Z28 a few years ago with 11k on the odometer, installed ARH LTs and left the mounts in, big mistake, y-pipe banged like a Tijuana hooker! I am running UMI solids now on my 99, did not want to mess with dis-assembly of the stock clamshell/reinstall with polys.
#815
EDIT: I don't think they would with stock k, but would check with UMI.
#816
You could be right, may just be too much flex in the stock mounts. Don't know if it's worth changing them with ony 1/16" clearance though. I think i'm going to just remove the brace and see if I can slot the holes to try and get 1/4" over toward the passenger side. If not I live with it or put in a different trans brace with a smaller footprint
#817
#819
It might have been addressed here but I don't really want to go through all 40 pages.
Can anyone confirm if the MWC 9" and their LONG torque arm will clear this exhaust? The pic above is a little blurry. Eric recommended the short as he wasn't positive if it would clear or not. But I'd rather do the long if I can. I'm lowered 1.25" Thanks!
If it does clear with the long arm how tight is it?
EDIT: Got under my car to check for clearance on the stock TA and I have a good 1/2" - 3/4" from my exhaust to the bottom of the TA. So if the MWC arm isn't lowered at all over stock with their relocation crossmember I should be fine.
Anyone know for sure....I may order my rear on Monday.
