comp 975 lifters
Old Jan 25, 2011 | 10:26 AM
r572cobra's Avatar
Default comp 975 lifters
anybody know the lifter preload,on these.
Old Jan 25, 2011 | 10:31 AM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
Are you sure it's a 975? Maybe an 875 instead??
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Jan 25, 2011 | 01:08 PM
r572cobra's Avatar
your right i meant 875.thanks
Old Jan 25, 2011 | 05:49 PM
JPH's Avatar
JPH
run .020-.040 hot.
Old Jan 25, 2011 | 06:07 PM
r572cobra's Avatar
I checked the pushrod length an got,almost 1.5 turns.then checked with a dial indicator,and got about .070 ths.this cold on the engine stand.buddy of mine built a ls3,with far heads,same lifters,060.preload,and 7.4 pushrods.6k on motor with no problems.what do you guys think?
Old Jan 26, 2011 | 10:19 AM
r572cobra's Avatar
nobody else have any imput on this,i really dont want to spend the money,on another set of lifters if I can make these work.
Old Jan 26, 2011 | 10:25 AM
If you've got the 875's, you need an adjustable rocker to setup preload properly! They require .002-.004" of preload, otherwise you'll have problems (noise just being one of them).
__________________
Old Jan 26, 2011 | 12:57 PM
r572cobra's Avatar
I understand what you are saying.read on here,some people are using stock rockers,with no problems and would like to here from them,thank you.
Old Jan 26, 2011 | 01:28 PM
Yes, some get away with a stock rocker on the 875 lifter combos....but you have to get VERY close on the preload to start, and then you shin them to get the preload where you want it. The issue with that is you start messing up your geometry just to get the right preload, which is no better than having the wrong preload to start with!
If you search on here, you'll find a few people who have been successful with the stock rockers using this method, but 99.5% of them will complain of loud valvetrain noises and/or instability, and then having switched to an adjustable rocker.
__________________
Old Jan 26, 2011 | 01:34 PM
Darkman's Avatar
https://ls1tech.com/forums/generatio...oad-setup.html
https://ls1tech.com/forums/lt1-lt4-m...djustment.html
https://ls1tech.com/forums/generatio...r-lifters.html
https://ls1tech.com/forums/generatio...-collapse.html
Old Jan 26, 2011 | 07:35 PM
r572cobra's Avatar
Darkman,I noticed most of those post,were in 04/05 years.did comp fix the problem?I checked with a pushrod checker and 7.300 will give me the right preload cold.I'm running a big comp cam 474-11,251/267.624 lift.the motor is not in the car yet.pushrods are cheaper than lifters.
Old Jan 26, 2011 | 07:50 PM
Darkman's Avatar
The main issue here is not a lifter manufacturing problem, it is rather a deliberate design feature - these are close-tolerance high performance lifters.
The pre-load range is from 0.002-0.004 inch. (One poster above misstated it.) You cannot establish a pre-load level within plus/minus two thousandths of inch using a pushrod checker nor can you measure it based on the number of turns on the OEM rocker.
The simple fact is, if you do not have an adjustable valvetrain you cannot set and maintain these lifters to the manufacturer's specifications. Thus you cannot expect them to be reliable.
Old Jan 26, 2011 | 07:56 PM
SweetS10V8's Avatar
Yup,
You can use 875s if you have an adjustable valvetrain. If you have a non adjustable vavletrain you have to use the 850s. I have the 850s in mine.
Old Jan 27, 2011 | 09:53 AM
Precisely. Well stated.
__________________
Old Jan 27, 2011 | 10:01 AM
r572cobra's Avatar
will the ls7 lifters be okay with that size cam,i cant afford the rockers right now.
Old Jan 27, 2011 | 12:09 PM
Darkman's Avatar
LS7 lifters will work with that cam providing, of course, that you don't plan on operating at some unusually high rpm level.
