Diy sheet metal ram air?
Old 02-22-2011, 10:44 PM
pyro719's Avatar
Default Diy sheet metal ram air?
Anyone ever made one? I'm about to build my own and just wondered if there is writeup for this some where?
Old 02-22-2011, 11:00 PM
The Mighty Texan's Avatar
chrs1313 did his own. Im sure lots of people have, i wanted to also but i dont have access to any fab tools anymore.. if you got the stuff it shouldnt be that hard at all, could even do an aluminum one if you got a tig or something
Old 02-22-2011, 11:02 PM
pyro719's Avatar
All you need is, Sheet metal, rivet gun, a 2x4 and nascar tape.
Old 02-22-2011, 11:08 PM
Yeah i guess you could just do it that way too! The other thing that stopped me was i didnt have any dimensions, shouldnt have been that hard to get my own but i was pretty busy. Ended up just buying a used one for a pretty good deal
Old 02-22-2011, 11:15 PM
pyro719's Avatar
I just cant justify spending $200 on something I can fab for $20 LOL
Old 02-22-2011, 11:19 PM
Oh yeah no doubt. I got mine for 50, there was no way in hell i was going to pay 100+ for some damn sheet metal. Even 50 seemed like alot haha
Old 02-23-2011, 08:56 AM
pyro719's Avatar
I have hard time believing none of you guys have made your own
Old 02-23-2011, 05:49 PM
shiv15's Avatar
Look up sux2bu ramair. Not sheet metal but its probably even easier.
Old 02-27-2014, 11:28 AM
countryguy1717's Avatar
I didnt run the sheet metal version. I cut a two small holes in the core support, covered with mesh screen to avoid large debris in the filter, ran hose to the bumper grill, cut a small piece of the foam out. I didnt want to do much metal cutting due to safety but along with the stock plastic air dam that runs air up to the box I think it should be a little better airflow than stock with a lid.
Old 02-27-2014, 11:40 AM
Moderator
jimmyblue's Avatar
One knock on the SLP CAI is that its stainless construction
makes it a bad heat absorber; you can see IAT come way
up swapping one of these onto a stock-cold-air car.
If I were you I'd consider something like ABS sheet, easy
to cut and solvent- or hot-air weld, capable of forming
with a heat gun, cheap and available in basic black. Way
lower thermal conduction and heat-mass than steel.
But consider, too, that airflow is helped only a little and
where you draw from (temperature) matters more than
cross-section forward of the filter element.
Old 02-28-2014, 06:03 PM
jlcustomz's Avatar
Here ya go. Sorry, no writeup. I handfabbed the aluminum top & butterflies. Functional linkage to throttle body. Sits over conical filter, has plastic bottom. Had to lower core support & radiator in vehicle to make room.
While not everybody likes the look, it is functional.
Quick Reply: Diy sheet metal ram air?
