ls6 intake
Old Feb 14, 2004 | 03:49 PM
2000blackta's Avatar
Question ls6 intake
i was just on TSP's website and saw that they have a deal going on for ls6 intakes. They also have a package deal with the 28.8 lb injectors and fuel rails off of the 01-02 fbods. I am definetly going to order the intake but wasn't sure if I should do the deal with the injectors or not....any suggestions?
Old Feb 14, 2004 | 04:51 PM
strokedls1's Avatar
I would just get the intake.
Old Feb 14, 2004 | 07:28 PM
so the injectors wouldn't make much of a difference then?
Old Feb 15, 2004 | 12:29 AM
Strahley's Avatar
No, I don't think you need to upgrade them just yet. Off the top of my head I don't remember what 2001 came with, what whatever size they are, I still have them, and I'm doing just fine. You may want to upgrade them if you are planning on getting quite a bit more power. For most bolt ons I don't think you would need to upgrade them, but if you get a stroker kit or a power adder of any sort, or what not, then yes you will need to upgrade them. But for now, you'll be fine
Old Feb 15, 2004 | 07:15 AM
smokin' joe 00 ss's Avatar
Since you have a 2000 you'll need a egr adapter too.
Old Feb 15, 2004 | 09:43 AM
I have done both rhe egr and air mods...sorry i didnt mention that before....thanks for the replies!
Old Feb 15, 2004 | 10:05 AM
The egr mod is not the same as egr adapter for the LS6 intake, you'll need to get or make a egr adapter if you get a LS6 intake so you can hook up your egr to the LS6 intake.
Old Feb 15, 2004 | 11:27 AM
no, i meant that i totally got rid of the egr and the air....i have to change my sig .....but still, thanks for the input!
Old Feb 15, 2004 | 11:42 AM
Ok I got ya now.
Old Feb 15, 2004 | 12:13 PM
Jason 98 TA's Avatar
LS1Tech Premium Sponsor
The injectors are really only needed if your going to be running dry nitrous or bigger plans down the road like heads/cam.
Jason
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old Feb 15, 2004 | 05:21 PM
PongoX11's Avatar
You want to make sure the TSP intake comes with gaskets, I know they didnt before and its a $40 gasket set
Old Feb 15, 2004 | 07:47 PM
gMAG's Avatar
Gaskets come with PN88894339 from GMPartsDirect for $361.50, + $23 for air bleed pipe, +$2.53 ea for plugs (2 needed). And yes, please do read thread above "Is 2001 LS1 intake same as LS6?" Don't know if TSP provides gaskets. I'll gladly support our sponsor(TSP) if so.
Old Feb 15, 2004 | 09:26 PM
Geez, now i don't know who to order this thing off of....guess i'll have to find out if TSP ships the gaskets with the manifold or not and which company the shipping is better with ....oh well
Old Feb 16, 2004 | 09:00 AM
gMAG's Avatar
GMPartsdirect total for pn88894339 manifold w/gaskets $361.50, pn12568478 air bleed pipe $20.83, pn12563325 plugs $2.53eaX2, + shipping to PA=$440.78
Verify this from GMPartsdirect, then compare w/TSP
BTW, I'm willing to spend a few more bucks buying from our sponsor because I find that they're much more informative by phone than some of the "assistance" from the online stores. Good Luck! Glenn
Old Feb 16, 2004 | 10:43 AM
i think that i am going to order the one from TSP with the injectors because i do eventually think that i am going to do a head and cam package....so if this manifold doesn't come with the gaskets does anyone know where i can pick them up at?
