500Hp goal to the wheels Need Help!!!
wanting to reach 500 hp goal.. what do you suggest as far as mods to reaching this goal?
its a 04 z06 i have mounted LG 1 3/4 headers Kooks x pipe no cats slp loudmouth catback and a vararam CAI.. was thinkin of going with the ms4 cam and the trick flow 215 heads as the next mod?
Make sure you mill the heads & flycut your pistons for max compression. Also, get a hold of Tony Mamo & have him port you a fast 102. With a 102mm TB & mass air, it is possible. I'm at over 480whp with a similar combo w/o the ported fast. Also, check out Pat G's 500whp recipe thread. It's the best thread on here! Good luck!
You got your answer in the other thread you posted about this. 500rw out of a 346 isn't easy or cheap.
https://ls1tech.com/forums/generatio...heads-cam.html
