pics and how to install longtubes
also...get the car IN THE AIR high in the front. iirc the drivers side header slides in going straight up then rotated forward into place.
it wasnt hard at all, it was more of a PITA to get the Y pipe set right than anything, headers were easy.... just get it high enough, and snake them in
Look up the Pacesetter Longtube and poly mount for dummies. Great article. With a lift, it will go pretty smoothly I would think. If you have everything you need, it wont take long at all. I reused my stock gaskets and got new bolts. Most people get new bolts from GM.
There is a small metal tab on the drivers side of the block that you may need to file just a little to get them in.
Make sure you have extensions or new o2's just in case.
Good luck man.
