Painting a LS1 intake???
Old Aug 31, 2011 | 11:18 PM
Drew9585's Avatar
Default Painting a LS1 intake???
Any ideals on how to Paint a intake? What kind of paint? Is sanding needed??
Old Aug 31, 2011 | 11:53 PM
z99ls1's Avatar
Restricted User
Get an ls6 and paint it.
Old Sep 1, 2011 | 12:10 AM
LilJayV10's Avatar
First off clean it very well with something like Simple Green or Purple Power. Use some stiff brushes to get down in the corners where grease/dirt are.
As far as paint IMO you have a few options. I would suggest SEM spray paint for plastic. We use it at work and have had very good luck with it. I know they sell it in black(that's the only color we use)I would guess they have other colors too but I don't know.
If you decide to go with a custom color or if SEM doesn't have the color you want I would use some sort of adhesion promoter before the paint. What this does is soften the top layer of the plastic and it grips the paint better. We use PPG but I'm sure there are many different brands out there.
As always the prep work is the most important part. If the part isn't cleaned properly or the right steps aren't taken no matter how good the paint is it won't stick.
I would also suggest leaving the intake out in the sun for a little bit before you spray it so it's good and warm.
Hope this helps some.
Jason
Old Sep 1, 2011 | 01:06 AM
69cutlassrkt's Avatar
I used engine degreaser on mine and a brush, also pressure washed it. Mine has vht engine enamel gloss black painted on it.
Attached Thumbnails Painting a LS1 intake???-img-20110714-00148.jpg   Painting a LS1 intake???-img-20110716-00156.jpg   Painting a LS1 intake???-img-20110714-00144.jpg
Old Sep 1, 2011 | 01:09 AM
lemons12's Avatar
Krylon Fusion is good stuff too.
Old Sep 1, 2011 | 04:12 AM
omarrakeen's Avatar
cleaning is the most important as stated above. then sanding, primer or adhesive promotor then paint. i did mine 2 weeks ago it turned okay but not like what i expected..anyway heres a link in details. it turned out awesome. good luck
https://ls1tech.com/forums/appearanc...-thoughts.html
Old Sep 1, 2011 | 05:41 AM
Drew9585's Avatar
Alrighty Thanks. For a primer, do you think Bulldog would work??
Old Sep 1, 2011 | 05:53 AM
omarrakeen's Avatar
anything would do, most people use duplicolor.
Old Sep 5, 2011 | 11:42 PM
Double Aught's Avatar
After a thorough cleaning, I used a high temp paint designed for BBQ grills. The finish is very close in color to the factory LS6.
Old Sep 6, 2011 | 10:52 PM
zaaronz's Avatar
I would sand it, to get a smoother look. Thats what i did on mine. After sanding it, I was gonna paint it myself, but took it to a local paint shop and ask them for a price instead. They said they do it for 50 bucks- heres mine Im happy with it
Old Sep 11, 2011 | 06:38 PM
TKeeby79's Avatar
Looks good I am contemplating painting mine red.
