Balancer install
Old Sep 28, 2011 | 08:36 PM
Paul57's Avatar
Default Balancer install
What is the best way to install my underdrive balancer?? I have the option of trying it on an engine stand or in the vehicle?? I was concerned that I would not be able to put full torque to it on the engine stand (for fear of tipping it over)?? Any nifty tips or tricks?? I was trying to avoid special tools since I don't plan on doing this again for many, many years.
Old Sep 28, 2011 | 08:46 PM
cutlass_455's Avatar
Try it on the stand if you got the chance. If you got a flexplate on the crank put a ratchet extension thru one of the holes in the flexplate and rotate the engine around till the extension hits where the starter bolts to and put a rag or block of wood in there to protect the metal and that will be a good stop.
With your torque wrench dont be pulling the wrench upwards or towards you. Try a downward away motion. If you got a buddy over get him to try to hold your stand in place. It should be managable yourself tho, Ive done this myself.
Old Sep 28, 2011 | 08:59 PM
S10xGN's Avatar
I did everything but torque the bolt while on the stand. Bolt got it's final torque after motor was installed...
Old Sep 28, 2011 | 09:00 PM
98 White T/A's Avatar
I just did mine. Had the car on 6 inch ramps, only took the fan out (removed from the bottom), had my uncle there. It's better with 2 people, sum1 can hand you tools or a flashlight. And when you use the puller, dont be scared to tighten it a lot, the balancer will pop out, and then gradually come out.
Old Sep 28, 2011 | 09:24 PM
Paul Bell's Avatar
That's MISTER MODERATOR
I certainly hope you're properly pressing the balancer onto the crank with the correct tool, not the balancer bolt.
While many have done it without issue, some have had disastrous results when the bolt snaps or the crank threads strip. Do you really want to take the chance of being one of them?
The balancer bolt and threads in the crank are not designed for this.
https://ls1tech.com/forums/generatio...one-wrong.html
Old Sep 28, 2011 | 09:31 PM
reeperz28's Avatar
You do not have to use a tool to install it if you heat it up around 200 degrees just slides on then tighten 255 ft lbs to seat it all the way ...with the old bolt.. then 40 ft lbs + 120 degrees with new bolt.. according to asp's instructions
Old Sep 28, 2011 | 10:25 PM
Paul57's Avatar
I do have an install tool (threaded rod with nut).
Thanks for all the details. This helps a bunch.
Old Sep 28, 2011 | 10:40 PM
Paul Bell's Avatar
Good luck with the job.
Frozen Tundra? Where's that?
Old Sep 28, 2011 | 10:48 PM
Paul57's Avatar
Near Green Bay, WI
Old Sep 28, 2011 | 10:59 PM
Raptor_WS6's Avatar
what is the thread pitch on the crank hole? crank bolt?
Old Sep 28, 2011 | 11:06 PM
Paul Bell's Avatar
M16 x 2.0.
The bolt thread and crank thread match
Old Sep 29, 2011 | 06:39 AM
printmanjackson's Avatar
crank hole?
Old Sep 29, 2011 | 08:08 AM
Raptor_WS6's Avatar
Lol thx
Old Sep 29, 2011 | 01:28 PM
redbird555's Avatar
Like everyone here said either the tool or heat it. I used a tool the first time and it worked ok but was still a little tough. The second time I just heated it and it literally fell onto the crank lol
Old Sep 29, 2011 | 06:40 PM
gMAG's Avatar
The March pulley I have was from a batch that was machined incorrectly.
It was so tight, that even after heating the new pulley, it bent the aircraft hardened-thick washers on the threaded rod.
A friend recommended a shot of nitrous to the crank snout, next time.
I think that there won't be a next time, because that pulley will not come off using conventional means.
Old Sep 29, 2011 | 08:43 PM
SpinsB's Avatar
Might be a dumb question but when is a good time to go with a crank balancer puppy?
Old Sep 29, 2011 | 10:59 PM
SippiSpeedhawk's Avatar
I think any time is a great time for a puppy.... My puppy isn't very good at balancing my crank though.
I would do it with the engine out if possible. Or are you asking at what power level/rpm range?
