LS3/LS7 coil conversion to an LS1?
Do the new coils have any benifit? Do you need a different wire harness? I use Big Stuff 3 so I need to consider this. There supposed to be some truck coils that have the same bolt pattern too.
Any input will be appreciated!
https://ls1tech.com/forums/generatio...ls1-coils.html
Megasquirt actually tested the LS1, LS2, and LS2 Truck (D585 w/ heatsink) coils and its on their site I just couldn't find it, but the signals were much stronger than the LS1 and carried longer.
The Megasquirt pinouts are the same, but appear to show the plugs are different.
I am using BigStuff 3, so I do not have a ton of options.
https://ls1tech.com/forums/generatio...ve-covers.html
The coils are pretty cheap from Rockauto.
All the info and facts are here: https://ls1tech.com/forums/12985321-post1.html
"These LS2 coils are incredible. Even compared to the LS1 coil, these are just crushers! On the LS1 coil there is around 40 milliamps of peak secondary current with 5 milliseconds of dwell time. On the LS2/truck coil (AC Delco D585), there is 120 milliamps!"
Here's their video:
http://www.youtube.com/watch?v=C1WH0...ature=gv&hl=en
I'm Nev from Melbourne Australia ,
i have been reading through some great information you have shared regarding coil conversion from ls1 to ls3 and was hoping you coul assist me . I have been experiencing problems after my conversion from ls1 coils to ls3 on my 408 . Missfire at low rpm and hard cranking with pre- ignition when you need to start and engine is still close to operating temp. My tunner is telling me to go back to the ls1 coils . Would the table in the megasquirt manual be correct for my purpose
.To get 5.6 milliseconds of running dwell, the nominal dwell parameters should be set to:
Maximum Dwell 6.1 milliseconds
Maximum Spark Duration 2.0 milliseconds
Acceleration Compensation 0.6 milliseconds
Battery Voltage Compensation
Setting Net Voltage Dwell Compensation
-4.0 8.0 Volts 2.4 milliseconds
-2.0 10.0 Volts 0.9 milliseconds
0.0 12.0 Volts 0.0 milliseconds
2.0 14.0 Volts -0.5 milliseconds
4.0 16.0 Volts -0.9 milliseconds
thanks Nev
I don't believe any of my posts discussed swapping to LS3 style coils. I did talk a lot about using the truck coils with heat sinks, which are not LS3 coils.
I would not know why swapping from LS1 to LS3 coils would cause a problem. Other then their plugs, they are very similar.
I have not done any of the PCM changes myself nor would I be able to. I have not had any of the issues you've described.
My posts pretty much outline how to do the swap to the truck coils with the heat sinks and any PCM changes were done by the mail order tune people I use.
I'm sorry I can't be of any more help.
