car wont start/run
ok just trying to do some trouble shooting.....
I have a 2000 z28 with lots of goodies, the car has been sitting in my garage
for about 8 months untouched. I went to get it out the other day and wth car would not start, which I didnt think was crazy because it has been sitting so long. I hooked a battery charger up to it and all it would do was click, so I let it charge a while and went back and checked the it was 13.xx or 14.xx don't remember exactly. it will crank over and start every not and then but die soon after. if I hammer on the gas it will stay running for a few seconds but as soon
as I pull the battery charger off it will die.
so what are we thinking here....
could be a bad ground
could be a bad alternator
anything else you can think of for me to check?
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
Number 1, if it won't start without a charger attached you probably have a dead cell or two in your battery, which is not uncommon if you've left the battery connected while it was parked for 8 mos. If it dies when you remove the battery charger I'd look at your battery cables. The cables could be corroded through causing spotty connections, and also your alt could be bad and not recharging the system. With the battery just sitting it should read ~12V, with the car running it should be ~14.4V or so.
I've also had a previous car randomly loose power to everything and it was a cracked cap on the starter solenoid. Replaced the starter and it was all good.
The clue is the clicking starter. This is either a bad battery, or a faulty alternator, or both.
I think your battery is gone. Before you change anything, though, try disconnecting the battery, then use a known good battery from another car.
You can easily do this by using jumper cables to bridge between the 'new' battery, and the existing cables on the 'bad' car.
If the car now runs, connect a voltmeter across the terminals of the 'new' battery, and verify that you see 14v or more. This should prove that your alternater is charging the battery properly.
If not charging, take the alternator to AutoZone. I think that they'll test it for you.
My car has also been sitting for about 7 months. I know my battery is dead but do I need to worry about bad oil or gas or anything? I'm draining the radiator and using new coolant before I start it. Will anything just go bad sitting around for so long? It has brand new full syn oil in it and very little gas. I will throw a few buck of 94 octane in before starting it up. Water pump took a dump on me and it's just sat.
