ls6 or fast
Old Jun 24, 2012 | 10:54 PM
  #61
lemons12's Avatar
Originally Posted by Blk98Vert
Lies! Dont you know as soon as you touch the motor Greentops are mandatory?
Ha.. I didn't, but I do now!!!
I'm running stock 42# anyway, so I could care less... I also run a stock intake that flows equivalent to a 102... I think I'm covered on the stock VS aftermarket parts.
Old Jun 25, 2012 | 12:03 AM
  #62
bww3588's Avatar
I changed the oil on my car and went straight to 96 lb injectors...don't want that syntec to max em out.
Old Jun 25, 2012 | 12:06 AM
  #63
lemons12's Avatar
110#ers or go home.
Old Jun 25, 2012 | 02:00 AM
  #64
bww3588's Avatar
Way too big for my application...next you'll be telling me a fast 102 is too big!
Old Jun 25, 2012 | 02:11 AM
  #65
lemons12's Avatar
The losses with a FAST 102 below 1,350 RPMs are WAY too much for me.. I just can't get the car to move... I had a ported one and I had to have the idle set at 3,000 RPMs just to get enough air moving to keep it running.
The things are ridiculous I tell ya.
Old Jun 25, 2012 | 02:44 AM
  #66
Blk98Vert's Avatar
I dont even have a throttle body, I need that much air
Old Jun 25, 2012 | 02:52 AM
  #67
lemons12's Avatar
Too much air can be hard to tune though....
Old Jun 25, 2012 | 02:56 AM
  #68
Blk98Vert's Avatar
Thats why you add injector
Old Jun 25, 2012 | 03:11 AM
  #69
lemons12's Avatar
How silly of me... I'm a noob.
Old Jun 25, 2012 | 04:07 AM
  #70
bww3588's Avatar
I'll probably just leave the intake out of the equation. Just run open ports with a 5 gallon gas can sitting on top with 8 feed lines.
Old Jun 25, 2012 | 04:13 AM
  #71
lemons12's Avatar
Identical to open headers.. You might get a false knock sensor reading but no biggie.
Old Jun 25, 2012 | 04:27 AM
  #72
Blk98Vert's Avatar
What the hell happened to this thread lol
Old Jun 25, 2012 | 08:34 AM
  #73
R6cowboy's Avatar
You and lemons needed some sleep???
Old Jun 25, 2012 | 01:00 PM
  #74
SStressin's Avatar
get the new fast 92 that is back!
Old Jun 25, 2012 | 01:01 PM
  #75
Blk98Vert's Avatar
No...
Old Jun 25, 2012 | 01:32 PM
  #76
bww3588's Avatar
Back from what?
Old Jun 25, 2012 | 01:39 PM
  #77
lemons12's Avatar
Back from what?
Kenny Chesney concert.
Old Jun 25, 2012 | 01:42 PM
  #78
Blk98Vert's Avatar
Back from what?
The 92 is rereleased for $850 plus shipping, roughly $100 more than a new 102
Old Jun 26, 2012 | 04:16 PM
  #79
svede1212's Avatar
I tried reading through this thread and it's interesting to say the least. i recently put on a 102, NW 102 TB (MAFless) and BBK rails. I was told the 102 wouldn't work with green tops (FWIW I was near maxing out my stock LS1 injectors, +85%, with just cam/headers), I was told it was too big, I was told it was hard to tune and drive.
Turns out the green tops fit right in with minor dremeling the edges of the mani adjacent to the injectors. Tuning was nearly non-existent in the low end. I had to touch my RAF idle table. In the high end I had to add fuel everywhere as it was nearly 5% lean indicating more air. Driving in stop and go I really don't notice any changes. Stepping on the loud peddle tho had my stage 3 clutch slipping a little in third gear and my hemorrhoidal butt dyno says I picked up a bunch of HP over my LS6/80mm. Having a GTO I had no issue with the water pump. The only hiccup was I had to tap my front steam pipe down a bit to clear the TB. I checked the match to ports with the top off and it was almost a perfect match to my ported/milled 243 heads. I'll be heading to the dyno in a couple of weeks and we'll see but having driven this car for 8 years I'd be amazed if I hadn't picked up quite a lot.
