GM Head Bolts Break?
I'm having new heads installed this week and I got a call saying one of the gm head bolts (new) broke off into the block as they were torquing it down. This is a reputable shop. Anyone else have this issue?
Is it a reputable LSx shop or a reputable auto repair place? I've never had it happen to me and I've done both my cars. Haven't heard of it happeneing either. I suppose a bolt could have been defective. And LS heads are degreed in steps rather than torqued.
It is more likely there was water or trash in the holes or they were over torqued than more than 1 of them was defective I would think.
It is a lot more time consuming to get all the coolant out of the holes than most people think. Simply spraying compressed air into the holes for a second won't do it. I did that several times but still was able to get a bunch out by twisting up paper towels and shoving them to the bottom. Soaked up about 2 paper towels in each hole.
****, it took me longer to get all the coolant out of the holes and chase the threads than it did to remove and install the heads......i used q-tips taped to the end of a big zip tie and ARP thread chasers. So i agree with the above they probably torqued them with crap in the bolt holes
So much win.
What did the shop have to say about what caused it? I always do my major jobs at my friends garage and hes got a blowgun for an air hose with a piece of 3 foot brake line screwed into it to blow the holes out with. Works like a charm.
If it's a reputable shop then I would lean towards the block or bolt but hey ... mistakes can happen to the best of us.
ARP Cylinder Head Studs [12-POINT NUTS] (1997-2003 GM LS1 & LS6)
ARP Cylinder Head Studs [12-POINT NUTS] (2004-2011 GM LS Series)
