So who's going to be the first to try this?
Old Mar 11, 2013 | 11:24 PM
sciff5's Avatar
Default So who's going to be the first to try this?
http://compare.ebay.com/like/3308842...Types&var=sbar
Even if the actual throttle bodies were junk you still might be able to use the casting with some sport bike throttle bodies
Old Mar 12, 2013 | 05:32 AM
dr_whigham's Avatar
The Scammer Hammer
Veteran: Marine Corps
It's certainly piqued my interest...
Old Mar 12, 2013 | 05:35 AM
ss4chad's Avatar
That's neat!
chad
Old Mar 12, 2013 | 05:48 AM
Slowbird780's Avatar
That looks awesome, to bad half of it ends up under the dash hidden lol
Old Mar 12, 2013 | 07:32 AM
Paul Bell's Avatar
That's MISTER MODERATOR
That would certainly NOT fit under the cowl of a F-body.
The fuel injector bungs look very far away from the valves.
I don't see a provision for an IAC which would need to feed all eight runners.
Looks neat tho.
Old Mar 12, 2013 | 09:08 AM
outkast6991's Avatar
I can't figure out where the tb linkage would be. That could be an issue as well as the injector placement
Old Mar 12, 2013 | 09:39 AM
Snkebait95's Avatar
Ive always wanted one, not much info on how it performs. Anyone know how these itb style intakes perform?
Old Mar 12, 2013 | 05:35 PM
dailydriver's Avatar
Just look at one of the Katech built powerplants under the hood of the C5/C6R road race Vettes to find out if they "work" or not (and those are all inlet restricted).
Just imagine what those engines would make TOTALLY un-restricted.
BTW; is OBX the Sino-made company which manufactures all of the Chinese stainless headers/y/x-pipes on fleabay??
Old Mar 13, 2013 | 07:25 AM
Snkebait95's Avatar
How does it get "cold enough" air?
Old Mar 13, 2013 | 05:16 PM
^^^ I don't know how these in particular get enough cold air, but the road racing versions all have a plenum attached to each bank of stacks, fed by a 'snorkel' which draws in air from a high pressure area in the front airdam.
Old Mar 13, 2013 | 05:44 PM
dr_whigham's Avatar
The Scammer Hammer
Granted I've never seen one myself, but I'm curious if it could be used to work with the 6LE shaker hood? Maybe? IDK, just a thought....
Old Mar 14, 2013 | 05:48 AM
ss4chad's Avatar
That would look awesome on an Old Chevelle or an ElCamino with an LS motor!! Pop the hood and BAM!!
Chad
Old Mar 14, 2013 | 08:36 AM
Snkebait95's Avatar
Ah yeah, ive wondered what that thing was!
Old Mar 14, 2013 | 09:22 AM
Fred Flintstone's Avatar
Looks like a cheap knock-off of lucas fuel injection. The c5r used lucas fuel injection,
its been around for awhile. Is mostly used for road racing.
Old Mar 15, 2013 | 09:03 PM
jetboat's Avatar
That is not a bad price if the throttle linkage doesn't cost a arm and leg. But that would work and look good on my boat!!
Attached Thumbnails So who's going to be the first to try this?-best-pick.jpg
