Speed Engineering Race Version Headers Now Available!!
Old Apr 12, 2014 | 12:59 PM
  #281
JRENIGAR's Avatar
Originally Posted by CubanGT
Well that's a good thing all that's already off the car, and nothing is or should be in the way for my install.. I cant remember where I read it, but is it true that to reinstall my transmission I should leave the headers semi loose so I can move them to allow the transmission to go back in easily?
I just don't want to install the headers and torque to spec to have to loosen to position the trans back in place.. or install the transmission and then cant fit the headers into place..
Headers will slip right past the auto trans no problem. Just remove coil brackets, starter, and plugs and slide right in from the bottom.
Old Apr 12, 2014 | 10:39 PM
  #282
GarrettM's Avatar
In for the 1 7/8" group buy and willing to pay extra for a merge spike!
Old Apr 13, 2014 | 10:54 PM
  #283
CubanGT's Avatar
Here is a pic of the passenger side installed with bolts hand tight until transmission goes back in...
This side was a breeze, considering I had a lot of things out of the way already, took longer to get the back screw started than positioning it into place..
Old Apr 15, 2014 | 01:10 PM
  #284
demonspeed's Avatar
It's not mine! woo hoo!
Which is why header studs are $30 well spent
Old Apr 15, 2014 | 01:16 PM
  #285
CubanGT's Avatar
Maybe so but I had already spent the money on some other bolts a while back to make it easier to take off in the future..
Old Apr 16, 2014 | 10:07 AM
  #286
Tranz Zam's Avatar
I got mine installed a few days ago. They fit real nice, and are made very well. I have the Borla tunable catback and with the muffler bypassed its loud as hell and very raspy, so I'll be switching around the plates to get it flowing through the muffler again. It does sound very good at idle though.
The only thing I should have done is motor mounts, as the y pipe will hit the floor while decelerating. Its not the headers fault. I was just being a cheapass.
Old Apr 16, 2014 | 07:21 PM
  #287
big hammer's Avatar
as far as positioning, I usually cut the heads off a couple old bolts, slide the header and gasket over them. start a couple other bolts, then thread out the "studs". voila!
Old Apr 17, 2014 | 08:12 AM
  #288
GuardianMagnuSS's Avatar
So a 3-4 month wait for the 1 7/8" headers I'd definitely wait for these. Especially if the headers and ory pipe are close to the same price as another brands headers only. The merge spike would be nice as well.
How do I sign up?
Old Apr 17, 2014 | 09:31 AM
  #289
jt_2002_ta's Avatar
In for 1 7/8" group purchase!
Old Apr 17, 2014 | 10:39 AM
  #290
Speed Engineering's Avatar
Sponsor
Our 1 7/8" prototype came in earlier than expected. We should be receiving it today or tomorrow. I am tuning the car we are going to test fit them on today. The car currently has 1 3/4" longtubes on it. Curious to see how much difference it makes with 1 7/8".
We will also be building our first true dual exhaust system off the same car. It will be a 3" true dual kit with bullet style mufflers, and dump before the rear end.
Sean
Old Apr 17, 2014 | 02:29 PM
  #291
ez2cdave's Avatar
PICS !!!
You will find a bigger difference in performance as displacement increases, with the 1 7/8" primaries . . . The "future" might call for 2" primaries to be available for 408 and UP stroker motors !
Old Apr 17, 2014 | 05:03 PM
  #292
Sponsor
Didn't show up today. Should be tomorrow. Test vehicle will be a heads/cam 2000 Camaro. First dyno test will be our 1 3/4" headers with a Y-Pipe and a single cut-out. Second test will be our 1 7/8" headers with same Y-Pipe & single cut-out. And last test will be our 1 7/8" headers with our 3" true dual exhaust.
Sean
Old Apr 17, 2014 | 07:30 PM
  #293
RBD_305's Avatar
Sean
Yessssss!!!
Old Apr 17, 2014 | 07:40 PM
  #294
Cstone812's Avatar
In for 1 7/8ths
Old Apr 18, 2014 | 12:59 AM
  #295
97WS6SCharged's Avatar
If you guys build an over the axle kit is there any chance you would sell just the pipes which go over the axle? I don't need the rest of the exhaust or suspension pieces which would be required.
Also if you build it please, for the love of god, add braces between those two pipes so they can't contact each other.
Old Apr 18, 2014 | 03:52 AM
  #296
_JB_'s Avatar
I have an idea that people might be interested in. What about creating a similar, "smashed" driver side pipe like stock? That would help lowered cars gain ground clearance, and as long as the width of the pipe is increased it shouldn't have any negative effect on performance.
I'm excited for 1 7/8 headers, and true duals over the axle! Need any test cars, let me know.
Old Apr 18, 2014 | 07:03 AM
  #297
Originally Posted by _JB_
I have an idea that people might be interested in. What about creating a similar, "smashed" driver side pipe like stock? That would help lowered cars gain ground clearance, and as long as the width of the pipe is increased it shouldn't have any negative effect on performance. I'm excited for 1 7/8 headers, and true duals over the axle! Need any test cars, let me know.
like this right here
Old Apr 18, 2014 | 10:57 AM
  #298
Tranz Zam's Avatar
My Y-pipe fits real nice, and is not much closer to the ground then stock.
I took the car over a few large speed bumps and got no scrape. My car is stock height tho.
Old Apr 18, 2014 | 11:20 AM
  #299
Sponsor
Got some pics for you guys of the 1 7/8" prototype that came in. Welds and port work look great. Hope they fit.
Old Apr 18, 2014 | 12:31 PM
  #300
Cstone812's Avatar
Keep us updated
