Speed Engineering Race Version Headers Now Available!!
Old Jun 24, 2015 | 10:20 PM
  #901
Speed Engineering's Avatar
Sponsor
LS6427: We have never tried Hi Heat Powder Coating. I am not sure how it holds up. Everything we have done in the past has always been ceramic coated. I am only showing one website order going to Florida that came in today, and it was only headers no Y-Pipe. The headers shipped out this afternoon.
91lxstang: Headers are in stock.
We just found out this afternoon that the Y-Pipes are shipping to us now. We should see them on Monday.
Thanks
Sean
Old Jun 25, 2015 | 12:16 AM
  #902
91lxstang's Avatar
Thanks
Sean
Just placed my order for the 1 7/8'' Race Longtubes. Excited to get them. Hopefully they will be there by the time I get back home.
Old Jun 25, 2015 | 05:16 AM
  #903
LS6427's Avatar
Thanks
Sean
Ok, thanks. I'll have them ceramic coated here locally. I'll post pics of them after they are done so people can see how they came out.....
And I got my UPS tracking number just now.......
Thanks.
Old Jun 25, 2015 | 06:53 AM
  #904
warriorpluto's Avatar
Don't know why you guys had to drop one side of k member or starter.I never had to do that with mine last week.If I did,I can tell you I wouldn't have installed them if I had to do all of that. Did by myself in an hour and half. I put the car on Jack stands and the only one I kind of had a problem with was the passenger side. It did hit on the starter a little bit so I just put my Jack under it and jacked up on the header two times and it slipped right in.
Old Jun 25, 2015 | 07:06 AM
  #905
AnotherWs6's Avatar
Curious as to why people are considering coating a stainless header. Is it just for better heat retention/exhaust speed or something?
Old Jun 25, 2015 | 09:04 AM
  #906
CGSmith0524's Avatar
^^^^^ This! Why are you coating a Stainless Steel Header?!
Old Jun 25, 2015 | 11:35 AM
  #907
LS6427's Avatar
My Grotyohan 1 7/8" LTs were ceramic coated and the heat coming off them was minimal.......you could keep your hand right next to them and no heat was felt.
Heat coming off uncoated headers is friggin hot as *****.....starters stop working when they get hot.
And...literally 10 minutes after engine shutdown....you can touch my headers....or change plugs if you want to. No way you can do that with uncoated headers. Uncoated will stay hot for over an hour because the heads will keep them hot......
Old Jun 25, 2015 | 03:20 PM
  #908
1995_maro_z's Avatar
I got my headers today! They look fantastic, but I have a question that is maybe a stupid one... I orderd the optional gm gaskets and new bolts. My headers came with two different sets of gaskets. One looks like the stock ones that i pulled off of my car, and one set is in little bags and loks to be a soft, aluminum gasket of some sort. The question is: Which set do I want to use?!
EDIT: I just got done installing them, and I went with the ones that looked like the stock ones. I haven't started the car yet, but boy do they look great! This was the first set of headers I have installed on anything ever, but it was honestly not nearly as bad as I was thinking it would be. Perhaps that could just be because of the fitment of these headers though! I didn't have to remove anything on the passenger side except the coil bracket, and had plenty of room. On the drivers side, all I had to do was remove the steering shaft. I left the oil filter on, didn't grind the black or the k member or anything like that. I had no issues getting them in by myself, except that it was a bit of a challenge to hold them and get the bolts started without an extra set of hands. That being said, I am EXTREMELY pleased with the headers (1 7/8" race version). Thank you very much, Speed Engineering, for a well made/designed and affordable product!
Old Jun 26, 2015 | 05:52 AM
  #909
LS6427's Avatar
The GM metal crush type gaskets are the MUCH MUCH better gaskets. You paid $30.00 extra for them....why didn't you use them...?
Old Jun 26, 2015 | 08:47 AM
  #910
I didn't know which ones were the better ones haha. I did some reading, and found that a lot of people say that the Gm multi layered steel gaskets were the best header gaskets for the ls1. That being said, I looked them up on summit and found that they looked a lot like the stock ones, so I used those ones. If they leak, then I have another set! No biggie.
Old Jun 26, 2015 | 08:50 AM
  #911
I used the ones on the right.
Old Jun 26, 2015 | 09:35 AM
  #912
RedRocketZ28's Avatar
You used the correct ones.
Old Jun 26, 2015 | 11:39 AM
  #913
Awesome! Haha
Old Jun 26, 2015 | 05:49 PM
  #914
Mappinsj's Avatar
about to buy these on ebay from speed engineering, then have a full custom hand bent exhaust built after the headers to my tail pipes!!!
Old Jun 26, 2015 | 07:59 PM
  #915
Sponsor
Thank you again guys..
Sean
Old Jul 7, 2015 | 11:42 PM
  #916
Zach-R's Avatar
How hard is it to modify the y pipe so that it doesn't neck down to fit the stock catback? I don't want to weld the y to catback. I want it to clamp together so I can change it out or remove it if wanted later on. Thanks.
Old Jul 8, 2015 | 12:37 PM
  #917
Sponsor
If you're running a 3" cat-back you can just cut the tip off our Y-Pipe to match it, and use an exhaust clamp similar to this:
http://www.summitracing.com/parts/sum-693300/overview/
I would suggest at least tack welding it though. I am sure they could pull apart fairly easily.
Thanks
Sean
Old Jul 8, 2015 | 12:45 PM
  #918
ragtopz28's Avatar
Thanks
Sean
^^This^^ saw it off (it's actually bigger than 3") then weld to I pipe. That's what I did and resulted in almost 0 rasp!! see pics.
Attached Thumbnails Speed Engineering Race Version Headers Now Available!!-img_20140913_123401_033.jpg   Speed Engineering Race Version Headers Now Available!!-img_20140912_165329_501.jpg
Old Jul 8, 2015 | 12:58 PM
  #919
YURVIEW's Avatar
Default Speed Engineering Race Version Headers Now Available!!
I simply cut off where neck reduced. My dynomax 3" bullet then slid right on to the y pipe neck. Used clamp in link above, no welding. Hanging on like a champ with nothing else holding bullet on.... Haven't connected my axle back system yet
Old Jul 9, 2015 | 03:37 PM
  #920
Sponsor
ragtopz28: That looks clean. You defiantly take care of the under side of your car.
Sean
