Speed Engineering Race Version Headers Now Available!!
Old Mar 22, 2016 | 06:56 PM
  #1101
SlasherVRGR's Avatar
Default Speed Engineering Race Version Headers Now Available!!
Look what came in the mail yesterday!
Everything looks good, can't wait to install them!
Attached Thumbnails Speed Engineering Race Version Headers Now Available!!-attach4524_20160321_112851.jpg   Speed Engineering Race Version Headers Now Available!!-imag0149.jpg
Old Mar 24, 2016 | 09:52 AM
  #1102
Speed Engineering's Avatar
Sponsor
Thank you...
Sean
Old Mar 25, 2016 | 08:42 AM
  #1103
01Z0H6's Avatar
Got mine installed yesterday! Cannot believe how easily these went in, sound, look under the hood. The ONLY negative feedback would be the clamps. I have ran the TSP's, Pacesetters in other fbods that I have owned. The Speed Engineering Headers are well worth the $$$... Great job Sean!
Old Mar 29, 2016 | 11:06 AM
  #1104
OffspringZ28's Avatar
How is the valvetrain noise with these? That is my only real concern compared to the other 1 7/8" longtube manufacturers. Is a thinner metal used?
Old Mar 29, 2016 | 12:48 PM
  #1105
jaxcam02's Avatar
I just put these in and the installation was easy breezy, the only complaint I had was also the clamps. They were to small to fit around the joints so I had to buy crappy u-bolt clamps for the time being until I can figure out a clamp to use that wont sacrifice ground clearance these u-bolt clamps take away.
Overall, the sound is great with my factory exhaust, fit was good, I am pretty satisfied.
Old Mar 29, 2016 | 11:48 PM
  #1106
14BFF's Avatar
does C10 swap headers #25-1026 fit in 1980s K10 4WD Pickup ?
Old Mar 30, 2016 | 09:33 AM
  #1107
RebelExtrm02's Avatar
WALKER 33272 Mega Band Clamps. They around $8 a piece from Rock Auto. I've used them on every exhaust system I've had on my car and are the only clamps I've not had leak. I especially like them for the y-pipe to header collector slip connections. When you crank them down they'll stretch over and create a nice seal.
Old Mar 30, 2016 | 10:43 AM
  #1108
jaxcam02's Avatar
Awesome I might give them a try thanks for the info
Old Mar 31, 2016 | 09:51 AM
  #1109
Sponsor
14BFF: The only work on 2wd.
Thank you guys.. Ya, we are continuously working with the factory to provide better clamps. They have just recently added a wedge in the middle, which helps tremendously with clamping strength. Unfortunately, they didn't extend the straps to compensate. You can get the clamps on, they are just very tight. If you remove the wedge they should side on just fine. Or, if you grind a little of the wedge down it should side on smooth as well. Hopefully, our next batch will have a little longer straps.
Thanks
Sean
Old Mar 31, 2016 | 12:01 PM
  #1110
pferris's Avatar
Thanks
Sean
Came here to complain about the clamps, and see you are already on it. Wish I would Have came here before fighting them so much, and breaking every single bolt that was included.
Overall the headers and y-pipe are really nice, but I would suggest using some of the savings to go buy some good band clamps. Would still buy again though.
Old Mar 31, 2016 | 03:06 PM
  #1111
gothic_sera's Avatar
Just ordered a set of 1 7/8" headers via ebay (global shipping) for my 2nd gen Camaro... can't wait for them to arrive!
Old Mar 31, 2016 | 05:32 PM
  #1112
Stilo's Avatar
I have a 72 2wd k5 Blazer dropping in a 6.2 LS, my Blazer has a 6/8 static drop so ground clearance is my biggest factor, how low will the 1-7/8 hang below the frame rails, should I just stick to shorty headers? Any Pics of them installed?
Old Apr 1, 2016 | 10:59 AM
  #1113
Sponsor
Thanks guys..
Stilo: Our longtube headers are 16" from the center of the bolt hole down to the bottom of the collector. Hope that helps. If they are too low for you, our universal swap shorty headers will be back in stock next week.
Thanks
Sean
Old Apr 1, 2016 | 01:30 PM
  #1114
Stilo's Avatar
S&E: Thanks ill have to wait a few weeks till I drop it in and measure, I already have a set of your shortys but now im leaning towards the full size ones, and my buddy has a bagged 64 c10 gmc LS2 he's building and offered to take the shorty's off my hands
Old Apr 4, 2016 | 01:00 AM
  #1115
doubleu888's Avatar
Do you guys have better clamps for your 1 7/8 long tubes? I put what you sent on and they don't tighten enough to prevent leaks. They won't even fit around the slip joint to be tightened down without taking the camp apart, and then you can't get the nut back on.
Old Apr 4, 2016 | 09:15 AM
  #1116
jaxcam02's Avatar
use the Walker mega clamps mentioned above like 5 posts. I just put the ones I got on and they are the best clamps ever. Sealed up all my leaks. They wont fit the y-pipe to i-pipe though becuase they dont make a two size clamp so I'm stuck with a 2 3/4 inch u-bolt clamp there.
Old Apr 6, 2016 | 09:34 AM
  #1117
ICRAZY6's Avatar
Has anyone tried using V-band clamps and having them welded to the collector and Y-pipe and then on the Y going to the I pipe? I'm considering this as an option for my car as it would make pulling exhaust out so much easier (no lift). Also, is the Y-pipe shipped with plugs for the O2 bungs? Lastly, can someone post up a picture of how tight the system sits to the car floor once installed and how close the Y-pipe is to the cross member?
Old Apr 6, 2016 | 03:56 PM
  #1118
ssjason232's Avatar
Yep.
Old Apr 7, 2016 | 06:36 AM
  #1119
ICRAZY6's Avatar
That's what I'm thinking about doing. Do you have any issue with it banging on the floor pans? Anyone running a MWC Torque arm and have issues?
Old Apr 7, 2016 | 11:02 AM
  #1120
ssjason232's Avatar
No issues with it hitting anywhere. Still running stock torque arm.
