Speed Engineering Race Version Headers Now Available!!
Old Feb 11, 2016 | 05:00 PM
  #1061
JDMC5's Avatar
Originally Posted by gsxrdan2
Nice install i used the same clamps.just wondering what driveshaft loop that is?..
I'm wondering the exact same thing
Old Feb 11, 2016 | 05:04 PM
  #1062
JDMC5's Avatar
anybody know if the y-pipe is the same for both the 1 7/8" and 1 3/4"? I bought a set of the 1 3/4" back in the beginning of 14 and looking to upgrade to the 1 7/8". Wondering if my existing y-pipe will work.
Old Feb 11, 2016 | 06:22 PM
  #1063
Speed Engineering's Avatar
Sponsor
Looks like a Spohn:
http://www.spohn.net/shop/1993-1997-...fety-Loop.html
Yes, the Y-Pipe is the same.
Thanks
Sean
Old Feb 12, 2016 | 10:44 PM
  #1064
LS1 pwrd NOVA's Avatar
So which header to get?
3/4 or 7/8? Stock lq4 going in my sons ws6
Old Feb 13, 2016 | 04:02 AM
  #1065
SlasherVRGR's Avatar
7/8 even on a 5.7 they make more power than the 3/4.
Old Feb 13, 2016 | 05:41 AM
  #1066
Speed engineering, What header bolts come in the gasket kit you all sell?
Are they cheap or good bolts or studs?
Now when you say they make more power are we talking just peak hp & torque numbers or are we talking all through out the rpm range? The $50 difference between the two headers isn't a deal breaker for me I just want what's best for this car.
Old Feb 13, 2016 | 07:01 AM
  #1067
Mappinsj's Avatar
My 2000 SS with lid, KN filter, speed engineering 1 7/8 LTs. Ls6 intake. Put down 340/343 at 215,000 miles.
Never made less than 300 wheel torque.
Best out of the car was 12.5 with a 1.96 60' in great conditions. Is a 12.8 consistent car
a4 with 3.42
Old Feb 13, 2016 | 09:07 PM
  #1068
JDMC5's Avatar
what are your guys thoughts on the whole 1 7/8" is too big for 346 cubes? I've seen mixed reviews. I'm very close to putting a set in my car and doing before and after dyno testing and track times compared to my 1 3/4" on my car in my sig.
Old Feb 15, 2016 | 03:45 PM
  #1069
mjs1012's Avatar
I think 1 7/8 is fine on a stock cube ls1, especially with your combo. You have plenty of air coming in so why not have the bigger headers to let it all out.
Old Feb 15, 2016 | 04:15 PM
  #1070
rdcamaro's Avatar
Saw the true duals available now for Silverado, plan on buying headers and duals at same time for my truck. Any thing in the works on true dual set up for fbody? Be nice to buy 1 7/8's and true duals in one shot also.
Old Feb 15, 2016 | 05:27 PM
  #1071
Sponsor
Sounds good thanks. Yes, we plan on coming out with true duals for the F-Body as well. It will probably be the end of the year before we have anything available however.
Thanks
Sean
Old Feb 15, 2016 | 06:00 PM
  #1072
LS6427's Avatar
Originally Posted by Speed Engineering
Ya, we moved the collector down around a year or so ago about 3/8" of an inch for some of the guys with tweaked chassis. Some cars are literally 1 1/2" away from the bottom of the car, and we have seen extreme cases within less than 1/8" of an inch. Just depends on how true the car is. But, yes the collector was change around a year or so ago.
Thanks
Sean
My drivers side collector could have used 1 full inch of a bend downward to make it horizontal to the ground. I have stock motor mounts.
I wonder if I got one of the sets that were older....??
Old Feb 17, 2016 | 10:45 AM
  #1073
Sponsor
We only adjust it 3/8" of an inch for some extreme cases we had seen at the time. Most vehicles didn't need any adjustment at all. Either way we haven't sold the old version in over a year.
Thanks
Sean
Old Feb 18, 2016 | 08:18 AM
  #1074
wannabefastcrf's Avatar
will 25-1025 headers fit 67-72 c10's with 5.3?
Old Feb 18, 2016 | 06:01 PM
  #1075
YZFZ28's Avatar
I am considering these headers, and have read about the drivers side welded upward just like LS6427 stated in his post , would like to know how many have experienced this since the problem was supposed to be fixed, I don't mean to bring up a bad subject or be negative, I just don't want to have to deal with that problem, thanks.
Old Feb 19, 2016 | 08:19 AM
  #1076
AnotherWs6's Avatar
Thanks
Sean
Old Feb 19, 2016 | 08:53 AM
  #1077
Just Bought the fbody 1-7/8 header & y pipe for my sons stock lq4 swap in his 02 ws6 this past monday.
I wasnt sure which ones to get either as it may mainly stay a stock 6.0 for a long while, but you never know
May get 243s & a small cam one day and thats it.
Either way i dont think the header size is a big difference vs your pocket.
You cant go wrong with either unless you are making big power & then we all know what route you need then
Old Feb 19, 2016 | 09:00 AM
  #1078
How far is your passenger head from the firewall?
I have the holly swap kit, plates & pan only.
I didnt want to spend big money on headers yet.
This seems like a good plan.
Old Feb 22, 2016 | 10:08 AM
  #1079
Sponsor
wannabefastcrf: We actually have C10 LS swap headers:
http://www.speed-engineering.com/ls-...p-headers.html
YZFZ28: If we saw any additional issues we would have made a second change. They fit just fine.
AnotherWs6: Lol
LS1 pwrd NOVA: Thank you for your order. I can't remember how far from the firewall they are off the top of my head, and we don't have an F-Body on hand to take a look at unfortunately.
Thanks
Sean
Old Feb 22, 2016 | 03:30 PM
  #1080
YZFZ28's Avatar
thanks for the reply, I will be ordering soon.
