Speed Engineering Race Version Headers Now Available!!
Thank you guys for the business.. Yes, passenger side goes in without removing any major pieces. Drivers side just requires one steering shaft bolt to be removed, and pushed to the side. Other than that it should side right in with ease.
Thanks
Sean
The Y-Pipe on the other hand.....F*^K that sob. I had to walk away. The provided clamps don't fit well at all and when I did finally get them on they don't actually squeeze the pipes together. Ill be going to a local exhaust shop and grabbing some better ones in the morning.
SE knows the clamps suck, they mention it a couple of times in what is now a giant thread. They also recommend which ones to get. Kind of weird, I know, but they give you these and then tell you to get those. At least they're honest.
AnotherWs6: Our latest batch of Y-Pipes have a little bit better clamp than our previous one. They actually listen to our bitching lol. If you look at the picture our clamps now include the center wedge on the bolt, similar to the Magnaflow clamp we were recommending.
Sean
Sean
Even the new and improved ones pictured above wouldn't clamp down enough to hold the joint firmly. Even after impacting them down I could still slip the pipe off.
my buddy and I replaced my Hooker LT 1 3/4 headers and y-pipe and installed Speed Engineering 1 /7/8 LT headers and off road y-pipe (Part #: 25-1020+25-1002). The headers and y-pipe went in smoothly with no issues but when I tried to connect the y-pipe to my Magnaflow exhaust, (Part #: 15684), the tubing was to long. Looking at it from under neath my T/A, the tubing connect to the y-pipe would push past the connection that goes over my rear-end.
It looks like I need to cut off about 2" inches off the tubing but I was wondering if anyone else had similar issue(s) or may have another solution on this setup. Thanks for any advice/help.
