Speed Engineering Race Version Headers Now Available!!
Old Sep 21, 2015 | 08:25 AM
  #1001
AnotherWs6's Avatar
A couple of things...^^^^
One, that's awesome.
Two, look at that torque curve.
Three, isn't your AFR a little on the scarier side?
Four, your exhaust - so you replaced the resonator thta came with the LM1 with a dynomax bullet? How does it sound? rasp?
Old Sep 21, 2015 | 08:40 AM
  #1002
paradigmGT's Avatar
Thanks. Car has always felt strong, just needs 4.10 gears. It only has around 40k miles (not sure if this would help).
AFR is definitely scary, and I have since had it re-tuned (actually had it re-done yesterday). However, the sensor that they placed in the exhaust actually popped out of the exhaust towards the end of the dyno pull, so I think that contributed to the scary readings.
I purchased the SLP LM1 without the resonator section, and welded in a dynomax bullet muffler. The car is loud, drones a bit around 2000 rpms in 6th gear and sounds wicked nasty (not sure how else to explain it, this may be referred to raspy) under wide-open throttle. Overall it is a higher pitched, louder more raspy sound compared to my lower rumbling Flowmaster American Thunder Cat Back.
Old Sep 23, 2015 | 03:02 PM
  #1003
Reaper-Z's Avatar
Defiantly getting a set of these headers/ypipe for my '98 Z28. I was on the fence about the gaskets as well. I did the same thing with my SLP LM1 setup on my '95 Z28 few years back. Like paradigmGT, I used the dynomax bullet along with a borla xr1 and a SW powerstick in the I-pipe section over time. All sounded great and had their own sound/rasp/drone. I liked the powerstick the best though.
Old Sep 24, 2015 | 02:36 AM
  #1004
GiggleJuiced_SS's Avatar
Put my 1" 7/8 LT's on the other night. Removed the steering shaft and they went in perfect. No cutting or hammering. I'm very happy with the fitment and looks. Props to speed engineering. I'll also be being a set for my 5.3 Silverado soon.
Old Sep 25, 2015 | 01:59 PM
  #1005
gsxkid's Avatar
I have an eBay code that saved me $20 on my headers from speed eng today
C20offsept
Old Sep 25, 2015 | 07:24 PM
  #1006
Speed Engineering's Avatar
Sponsor
Glad to hear. Thanks again guys.. I didn't even know eBay offered codes lol. I am pretty sure we got paid the same. Not sure how that works with them.
Sean
Old Sep 27, 2015 | 05:09 AM
  #1007
JRENIGAR's Avatar
Install update... The 1 7/8" installed exactly as the 1 3/4" did. I had to slightly grind off a casting ear on the drivers side of the factory k-member earlier this year when the 1 3/4" were installed. This was plenty of clearance for the larger tubes also. The pass side went right in without removing anything. I had to remove the mm to pedestal bolt in order to lift the drivers side of the engine an inch or so and they went right in. Keep in mind I already have poly mm's installed from the previous LT install. I also have a 4l80 trans with aftermarket cooler lines that were routed close to the factory locations but not exact. All in all a very easy install. Thanks Speed Engineering.
Old Oct 8, 2015 | 03:44 PM
  #1008
Sponsor
Thank you for the business..
Sean
Old Nov 8, 2015 | 10:24 AM
  #1009
Zach-R's Avatar
Just installed the 1 7/8 with ORY and poly mounts. No fitment issue but the Y pipe was a bit of a pain figuring out how to get it all together. Also no grinding of anything.
One thing though is I didn't receive enough clamps. The Y to I pipe section is missing a clamp since I had to cut my stock clamp off. The picture showed 6 clamps but I only received 5. How many should I have had?
Old Nov 9, 2015 | 01:00 PM
  #1010
rjla67's Avatar
Also installed mine over the weekend and installation was painless. However, as many has pointed out ditch the band clamps and either get Lap Clamps or do what I'm doing and weld the Y-pipe and exhaust. The clamps leak for you cannot get them to seal properly no matter what you do without running the risk of stripping the bolts.
Old Nov 9, 2015 | 06:52 PM
  #1011
Sponsor
Thank you guys for the comments, and business..
Sean
Old Nov 10, 2015 | 08:05 AM
  #1012
zman1969's Avatar
Sean I have been reading up here and went to your website and I'm leaning to 1 3/4" and didnt see them, they arent discontinued are they? I'm planning an engine swap to a mild LS6 224 cam and cnc heads, with normal SBC thats as big as they need yet so many are going 1 7/8"? my car is strictly street, little confused here. will the ORY work with either? I did find the 1 3/4 on amazon
Old Nov 10, 2015 | 11:34 AM
  #1013
z28_YOU_HO's Avatar
Best headers for the money hand down!!! Big shout out to speed engineering
Old Nov 10, 2015 | 02:10 PM
  #1014
AnotherWs6's Avatar
Cam and heads I think everyone will tell you to go with the 7/8's.
Old Nov 10, 2015 | 03:04 PM
  #1015
Sponsor
zman1969: Nope, we have both in stock. 1 7/8" would definitely be the way to go with a head and cam car.
z28_YOU_HO: Thank you for the comments..
Thanks
Sean
Old Nov 10, 2015 | 04:20 PM
  #1016
z28_YOU_HO's Avatar
Thanks
Sean
Thanks for saving me some money
Old Nov 11, 2015 | 11:56 PM
  #1017
Zach-R's Avatar
Fitment was great and no floor board banging like some have mentioned. I did the mounts too. I can't get rid of this exhaust leak though. Are there better band clamps I'm not a fan of welding it all together incase I ever need to remove it.
Old Nov 12, 2015 | 11:41 AM
  #1018
rjla67's Avatar
Lap band clamps
Old Nov 13, 2015 | 06:19 AM
  #1019
That_One_Person's Avatar
I was wondering if you guys are gonna have a sale for thanksgiving? Birthday's coming up and would love a set of 1 7/8 LT/ORY combo but I'll hold off a few days if there'll be a deal.
Old Nov 13, 2015 | 11:54 AM
  #1020
Sponsor
Ya, we dont plan on having any sales to be honest with you. We literally just price them to move.
Thanks
Sean
