Speed Engineering Race Version Headers Now Available!!
Old Apr 8, 2016 | 11:58 AM
  #1121
Cstone812's Avatar
It will work will every torque arm probably. I've got a Umi tunnel mount and it works fine. It tucks up real nice to. It does come with plugs for all the 02 bungs. You should replace those old motor mounts when doing header swaps to stop the banging.
Old Apr 8, 2016 | 12:55 PM
  #1122
Rise of the Phoenix's Avatar
Mine will be arriving Wednesday. Can't wait to get them on and see how much they pickup over the 1 3/4" headers I have now.
Old Apr 9, 2016 | 09:46 AM
  #1123
ICRAZY6's Avatar
I'm running poly mounts for the past year. Just a PIA to pull transmission. Had to pull intake off to get the top bolts.
Old Apr 9, 2016 | 12:00 PM
  #1124
Cstone812's Avatar
Pull the transmission for what? Lol
Old Apr 9, 2016 | 06:52 PM
  #1125
ICRAZY6's Avatar
I blew up an FLT level 5 trans and trashed the torque converter. They've since been replaced.
Old Apr 11, 2016 | 03:02 AM
  #1126
t_raven's Avatar
I've followed this thread for a while, but I don't remember if there was ever talk of possible making them for LS swapped 3rd gen F-bodies.
Hawk's 3rd Gen has their stainless works headers for almost $1100, the newer Hooker ones for $1100, or the budget ones for $700. $700 is pretty high when so many similar headers are $200-$400. As far as I know the Hookers require their engine mounts. If any other options exist for LTs I've never seen them.
A better, and cheaper option for third gens would be great. Have you guys considered offering them?
Old Apr 11, 2016 | 11:38 AM
  #1127
Speed Engineering's Avatar
Sponsor
Thank you guys..
t_raven: We believe our 25-1025-1 & 25-1026-1 might work on the 3rd Gens, however we have never personally done or seen a swap from a customer to verify. Those headers are tucked in very tight however, and should have enough clearance.
Thanks
Sean
Old Apr 12, 2016 | 08:30 AM
  #1128
t_raven's Avatar
Originally Posted by Speed Engineering
Thank you guys..
Thanks
Sean
Hmm, I have a couple 2nd gens, so maybe I'll buy a set and find out lol.
Old Apr 12, 2016 | 10:28 AM
  #1129
Sponsor
Sounds good. I know they fit the 2nd gens, but if you test them on any 3rd gens please let us know.
Thanks
Sean
Old Apr 14, 2016 | 08:04 AM
  #1130
Mine came in yesterday and they look great. Thanks guys!
Old Apr 14, 2016 | 08:11 AM
  #1131
ragtopz28's Avatar
Ordered my second set (for son's T/A build) and they are on their way!
Old Apr 15, 2016 | 10:17 AM
  #1132
Sponsor
Thank you guys.. Much appreciated.
Sean
Old Apr 21, 2016 | 02:10 PM
  #1133
gothic_sera's Avatar
My 2nd gen 1 7/8" F-body headers arrived about a week ago - took about 2 weeks to arrive in the UK. The box was a bit bashed and battered and one of the collectors a little flattened, but I sorted that quickly with a tube expander.
Very pleased with them and how they fit. Lots of room to the frame, and they tuck up to the floor nice and tight. Number 3 plug lead is very tight, but I swapped the standard connector for a slimmer one and it works OK now.
I had some flanges laser cut from 5/16" stainless at work and stitch welded them to the collectors. Mated up to my existing x-pipe after altering the lengths slightly, spacing was the same as my previous SBC.
So yes, very pleased with quality and fit.
Sera
Old Apr 22, 2016 | 07:52 AM
  #1134
Reaper-Z's Avatar
Where did you get that Xpipe piece if you don't mind me asking?
Old Apr 22, 2016 | 10:58 AM
  #1135
Sponsor
Looks great. Thanks again..
Sean
Old Apr 22, 2016 | 03:25 PM
  #1136
Summit - it's a generic one.
http://www.summitracing.com/int/part...2125/overview/
Want to replace the whole system with stainless at some point, but that can wait...
Old Apr 27, 2016 | 01:31 PM
  #1137
The 1 7/8" headers do have a merge collector, correct? Isn't that the cone that extends extrudes from where the individual primaries meet?
Old Apr 28, 2016 | 10:03 AM
  #1138
Sponsor
They have standard collectors with merge spikes on the inside.
Thanks
Sean
Old May 4, 2016 | 11:32 AM
  #1139
Can you recommend a set of ignition leads which will work best with the 2nd Gen F-body headers?
#3 plug is very close to #1 cylinder tube and even though I changed the boots to super skinny straight ones and put a heat proof sleeve over it, it's still getting burned.
I might consider putting a dimple in the pipe for a bit of extra clearance...
Would the high heat MSD style ones work?
Old May 5, 2016 | 08:23 AM
  #1140
Speed Engineering, do you guys know what the primary tube length is on the 1 7/8" headers? How about the primary collector length? Just curious because I'm trying to rule out why my setup lost HP from 6,000 rpm's up after I switched from Stainless Works 1 3/4" headers to your Speed Engineering 1 7/8" headers.
