FBODY: Is anyone using the Shaved Truck intakes
Old Dec 28, 2013 | 05:30 PM
RONIN LSX's Avatar
Question FBODY: Is anyone using the Shaved Truck intakes
So is anyone using the shaved/smoothed truck intakes in their Camaro or Firebird? If so, details and pics please!
*Not my pics
Old Dec 28, 2013 | 06:35 PM
01ssreda4's Avatar
I don't think they will clear without cutting the cowl. Most don't want to do that.
Old Dec 28, 2013 | 06:48 PM
GtoProject's Avatar
I was also wondering this. From what I've seen the truck intakes are far superior to the stock ls1 intakes and show some advantages to the ls6 as well. They pick up considerable low end torque and don't show any hp drop offs until the upper rpm range, somewhere at or above 6000 rpm. The only real problems with them is fitting them under the cowl; does anyone know if shaving is enough to squeeze them under? Also it was shown that when used with larger more aggressive cams their advantages slowly disappeared.
Old Dec 28, 2013 | 07:02 PM
RONIN LSX's Avatar
That's why this thread are for those that DID cut their cowl or is willing to.
Old Dec 28, 2013 | 07:03 PM
RONIN LSX's Avatar
I also read that the TBSS intake is even more superior than the regular truck intake.
Old Dec 28, 2013 | 07:22 PM
GtoProject's Avatar
From what I know the tbss intake is a much better option over the regular 5.3/6.0 intake. While they are less common and more expensive, in stock form alone they totally outperform the regular style truck manifold. They come stock with a 90mm throttle body that can be heavily ported. Also the intake itself can be heavily internally ported, some outside companies are offering it, but it costs quite a bit. By this point though, unless you are finding things cheaply an doing everything yourself, it's most likely more cost effective to buy a fast 90 or other competitive intake. On top I that you don't need to hack your cowl.
Old Dec 28, 2013 | 07:24 PM
RONIN LSX's Avatar
Well I don't mind chopping things up, as long as it will work.. plus I like different
Old Dec 28, 2013 | 07:52 PM
GtoProject's Avatar
A little digging found a nice comparison shot. Stock, non-shaved, truck manifold on the left and what I believe to be a ls1 on the right. Sadly it appears that even with extensive modification some cowl would need to be chopped.
FBODY: Is anyone using the Shaved Truck intakes-image-2623171446.jpg
If you could somehow get it in there though, it would look pretty clean. Here's another one done then sprayed with some gloss krylon. It would really pop out if put into a 4th gen engine bay.
FBODY: Is anyone using the Shaved Truck intakes-image-3901374996.jpg
Old Dec 28, 2013 | 08:00 PM
RONIN LSX's Avatar
Can the motors be lowered, which would give up some room
Old Dec 28, 2013 | 08:05 PM
omar2guy's Avatar
Here is mine but not going in an fbody
Old Dec 28, 2013 | 08:13 PM
GtoProject's Avatar
Most likely, but with that comes multiple other problems. Lowering your engine in turn lowers your trans, this causing shifter and mount problems. It would also cause multiple problems inside your engine bay as well as move exhaust much lower to the ground, which is bad news for those with lts. This could also throw off distance/geometry between trans, driveshaft, and rear, which may or may not be an issue.
Old Dec 28, 2013 | 08:18 PM
canada4g63's Avatar
it's been dyno proved that there isn't really any gains, I believe you can gain tq down low to to the longer runners, but the ls1 likes to rev past 5000
Old Dec 28, 2013 | 08:38 PM
RONIN LSX's Avatar
Well I guess that's not an option lol
Old Dec 28, 2013 | 08:39 PM
RONIN LSX's Avatar
What about with the 6.0 or bigger? I wish someone would do some dyno time with these and the LS intakes, for comparison. I like different, but I don't want to cut into **** unless there's something to gain from it.
Old Dec 28, 2013 | 08:41 PM
GtoProject's Avatar
I see this as more of a, because I can and want to be different, sort of thing. Just like I want to put a 8.1 496 tall deck in a 4th gen. While it may be easier, cheaper, and more successful to build a 6.0 I just think it would be sweet to say I have 500 ci big block and you don't. Fitting a shaved truck intake is the same thing, it's never, if seldom, been done and is something interesting to see in a engine bay.
I believe what would most benefit from this would be anything that would be mostly daily driven. The gain of low end torque would far exceed the loss in upper rpm hp. It may be able to increase mileage and would most likely give a bit more throttle response and bite off the line.
Old Dec 28, 2013 | 09:00 PM
RONIN LSX's Avatar
HAHA! You and I think alike!
I was thinking of doing one of the Avalanche BIG BLOCKs, but there's no aftermarket and I was told that they are weak.
Old Dec 28, 2013 | 09:19 PM
97WS6SCharged's Avatar
The runners in the truck intakes are shorter than the LS1/6 runners. The truck intakes also have more plenum volume to supply the motor. And they have no issue going past 5k rpm. The only downsides are they are big and ugly.
Old Dec 28, 2013 | 09:25 PM
OnlyACamaroCanbeAZ28's Avatar
you just grind it down smooth and then fill it? Looks awesome and I bought one cheap a few months back to try to do that with but have never gotten around to it.lol
Old Dec 28, 2013 | 09:33 PM
GtoProject's Avatar
HAHA! You and I think alike! I was thinking of doing one of the Avalanche BIG BLOCKs, but there's no aftermarket and I was told that they are weak.
The engine is one in the same. Vortec 8100. It's a fuel injected, coil per cylinder, 8.1 l 496 ci tall deck big block. 4.25"bore x 4.37" stroke. It's basically an older style 454 stroked to 496 and accompanied by new ls style electronics. Stock with a nodular cast iron crank and forged rods. The only real weak point is the pistons and rod bolts; throw in some forged pistons and a set of arp bolts and have some fun. With a little tuning and minor parts you can pull 350 hp and 500+ flb! Aftermarket is low but stock parts are easily modified. It's large aluminum intake and bulky iron heads are prime for porting. Many older style bbc internals are also useable.
Sorry for going off topic so here are some more pictures of a modified intake. There is one on a motor for reference to actual height, these things are gigantic. It seems if you go low enough into the ***** they turn into holes, which is why this one had an aluminum top cover put on.
FBODY: Is anyone using the Shaved Truck intakes-image-3330511291.jpg
FBODY: Is anyone using the Shaved Truck intakes-image-766612604.jpg
Old Dec 28, 2013 | 09:40 PM
99WS6_'s Avatar
I'm trying to put a 5.3 in my old school wat truck intake is the good one I'm guessing the nbs and nnbs 5.3 & 6.0 without egr correct?
