Help identify 243 head port work
Old Dec 27, 2014 | 08:47 AM
slonoma's Avatar
Default Help identify 243 head port work
A friend had these heads and said there was some bowl blending work done on these. Excuse my newbness, but can any one help me verify this? I can see some machine marks, but they look like they may be from replacing the valve seats. There is a slight lip on the back side of the seat, it's not sharp, but I can feel it with my finger. Thanks.
Old Dec 27, 2014 | 04:59 PM
JRENIGAR's Avatar
No work done on them that I can see.
Old Dec 27, 2014 | 05:51 PM
omc8's Avatar
Can you post some more pics and take some measurements inside the throat . There appears to be some work done but not much to get excited about .
Old Dec 27, 2014 | 08:06 PM
slonoma's Avatar
1.740"
Old Dec 30, 2014 | 10:36 PM
LilJayV10's Avatar
My guess is it's had new seats put in it. Those look like tooling marks not port work. Just my .02
Old Dec 31, 2014 | 10:44 AM
jimmyblue's Avatar
Moderator
I can't see someone having a die grinder in hand and
not even touching the valve guide bosses. And if you
feel a ridge on the back of the valve seat inserts,
ditto.
When I did mine there was plenty of evidence.
If they were "ported" at all, it wasn't enough to be
visible.
Old Jan 1, 2015 | 01:49 PM
KCS's Avatar
KCS
Moderator
They may have had a valvejob. Those cuts in the throat could even be from the factory valvejob.
Old Jan 3, 2015 | 11:57 AM
omc8's Avatar
The only thing I see is the chamber wall on the intake has been un shrouded. They are 2" valves correct ? Get a good valve job and open the throat up 1.78 - 1.79 blend the bowl and call it a day .
