Motor mounts / headers
Old Apr 12, 2015 | 03:33 PM
TA_Freak's Avatar
Default Motor mounts / headers
It all started with the replacement of my stock oil pump. It's turned into - let's take the TA down for a few weeks and take care of a long list of things .... "because I'm there."
Apparently I will save myself a lot of time with the mounts by removing the exhaust manifolds. Do I really want to ever put them back on? This is my DD and I need to pass emissions..... so should I go with headers?
Old Apr 12, 2015 | 03:45 PM
ULTIMATEORANGESS's Avatar
what kind of emissions testing do they have where you live?
Old Apr 12, 2015 | 03:53 PM
TA_Freak's Avatar
Pretty much just the OBDII scan and fuel cap. Occasionally they'll break out the exhaust sniffer.
Old Apr 12, 2015 | 04:33 PM
Smile
then id look into some LTs.
Old Apr 13, 2015 | 05:15 PM
Darth_V8r's Avatar
Moderator
If you get long tube headers, you'll need to delete AIR and EGR if you have it. Also, you might end up needing to delete rear oxygen sensors. Many tuners can deactivate these codes so your light stays off. If you get a cat'ed y pipe and keep your cam close to stock, you'll still pass sniff tests.
AIR simply heats the cats up
EGR is deleted at factory in 01-02, so obviously not needed
Rear O2 sensors just tell the computer the cats are working.
Old Apr 14, 2015 | 05:51 AM
wicked383lt1's Avatar
I say move out of that state...my .02
Old Apr 14, 2015 | 12:57 PM
TA_Freak's Avatar
Good info. Thanks. I've decided to stick with the manifolds and keep it a tame DD. My `79 Firebird is vulgar enough so when I feel untamed I'll drive that.
I hit a brick wall several days ago and lost the desire to wrench on that thing at all. What could have taken me a couple of days is now probably going to be a couple of weeks hitting it here and there. After driving the Firebird yesterday (knowing it's my DD right now) - that will be motivation enough to get the TA done.
Old Apr 20, 2015 | 09:40 PM
TA_Freak's Avatar
Made some progress on it today. Engine is up, k-member lowered and oil pan out. Motor mounts and pedestals are out. I'll take them to work tomorrow and drill the rivets. I really didn't have any issues at all getting the mounts and pedestals out with the exhaust manifolds on. I also was using an air ratchet with a swivel and different combinations of extensions.... etc. Now its just put it all back together. I can wait to fight with those mounts. I think I'll take the mount through bolts to work tomorrow and grind them to a point.
Old Apr 21, 2015 | 09:05 AM
Darth_V8r's Avatar
Moderator
Before you grind them down, there is a sticky with an awesome trick. Get the bolt in on the driver's side while you have freedom of motion with the engine. On the passenger side, take your car scissor jack and put it in on the strut tower. Press against the motor mount (make sure you aren't crushing anything on your strut tower wall). A few good cranks on the jack, and the hole will line up, and you can just push the bolt in. That's how I did it, and I had nobody helping me with the job.
Old Apr 21, 2015 | 09:08 AM
Darth_V8r's Avatar
Moderator
https://ls1tech.com/forums/generatio...otsa-pics.html
Post #6. There's alot of pics, so it's a long scroll to get down there
Old Apr 21, 2015 | 01:21 PM
TA_Freak's Avatar
Thanks ... yeah I've seen that one before. I am working alone. I'll give it a shot.
Old Apr 21, 2015 | 01:25 PM
TA_Freak's Avatar
Default Pics
Here's a few pics because there's an old saying that if there are no pics, it didn't happen. LOL.
Attached Thumbnails Motor mounts / headers-img-20150421-00125.jpg   Motor mounts / headers-img-20150421-00122.jpg   Motor mounts / headers-img-20150421-00121.jpg   Motor mounts / headers-img-20150421-00119.jpg
Old Apr 28, 2015 | 12:49 PM
TA_Freak's Avatar
Yesterday I started putting everything back together....only to find that when installing my rollermaster timing chain set, I need a puller to get the crank gear off. OK ... even with a key way on the crank? Anyhow, gonna have to grind down the 3 jaw puller ears a bit so it can fit behind the gear.
As for the mounts, they're ready to go in as well. Since I have the K member lowered and the engine raised (so I could remove the oil pan), I was thinking that I should be able to attach the clam shell loosely to the pedestal and install it that way. Being able to jack/move engine and K member should help.
Old May 4, 2015 | 10:08 PM
TA_Freak's Avatar
Today I wrapped up the motor mounts. I found it quite easy with the k-member lowered 4 inches and the engine raised. I had tons of room so I put the through-bolt in loosely. I also loosely mounted the clamshell to block and a combination of jacking up k-member/lowering engine brought the pedestals close enough to start the upper two bolts to each k-member. Further lowering/raising the engine/k-member allowed me to bolt the lower 2 pedestal bolts as the pedestals became flush on the k-member.
It's my opinion that it would be a heck of a lot easier just lowering the k-member a bit when doing this. It's only 6 bolts, 4 lower shock bolts, steering coupler. Everything is cake to get to and it just gives you tons of room to work as well. Throw in an air rachet, deep well 13mm, racheting 13mm, extensions and swivels, theres no reason one couldn't do this in 4 hours.
