New Hooker 4th-gen F-body Headers and Exhaust
#421
In all fairness to the poster, he has had an order in for seven weeks that hasn't been filled and the fault has been on Holley's end of things. Holley is a large company and back order issues do occur from time to time,,,as costomers we all have to decide to wait out such situations or move on to something else.
#422
Dumb question time...since the asymmetrical exit/tips seems to be an issue for some potential buyers, is it even possible that as a future design revision the mufflers be developed with offset exits? Is there enough room in the 6" diameter of the muffler there that if the exit wasn't concentric to the body of the muffler, they could be rotated and welded such that the two exits are equidistant to the vehicle centerline?
Seems that Hooker really put a lot of thought into these, so I am assuming it's just not possible with the unmodified vehicle body and the 6" mufflers. I had to ask though.
Also, if the tips in their current state work with the stock T/A bumper cutouts, then I would have to ASSume that they'd work with the 6LE dual/dual Camaro valence as well, being that every other catback can be fit on the stock Pontiac or 6LE Camaro variant of the F-body, right? (that's not a question for Toddoky, but for the overall LS1 community)
#423
#424
I can help you guys on this one. A custom CME set-up would be possible to fabricate for sure using a couple of 4" centerline radius U/J bends. Moving the driver side muffler over in order to create a centered dual single outlets is not possible however, unless you are willing to notch the side of the storage well and re-configure the hanger rods on the muffler.
#425
I don't know, but a can of VHT high temp black paint would do the trick if someone wanted to mask the polished mufflers.
#426
After 10 years and only 26K miles I'm thinking of replacing the stock exhaust on my '02 Z28 convertible. I really like the idea of a true dual cat-back set up, eliminating the factory Y-pipe. I plan to keep the factory manifolds and cats.
Will the Blackheart 70501332-RHKR (all 304SS) and 70501432-RHKR (409SS) also work on the 2000-2002 F-body CONVERTIBLES?
Assuming I'll have to toss the factory stamped X-brace, does Hooker P/N 71223001HKR (1993-2002 GM F-Body Floor Brace) replace the GM OEM X-brace where the factory Y-pipe is flattened? Will this work on convertibles too?
Thanks,
Tim
Thanks,
Tim
#427
FYI, I called their tech line and there are no notes regarding convertibles. Assuming that their floor brace is needed for the new duals instead of the factory Y-pipe, that might be something that Hooker wants to mention.
#428
Validating the fitment of the system on a convertible was not included on the development plan, so it's anybody's guess at this point if it would fit or not. Your suggestion to exclude convertibles from the application listing is a good point and something that got overlooked...thanks for the reminder, I'll have the website description revised on Monday.
#429
It might be a good suggestion to note that the GM factory tunnel brace may need to be replaced with the Hooker floor brace or similar aftermarket part in order to provide ample clearance for the 2.5" round pipe replacing the GM flattened Y-pipe.
I've ordered the 304SS 50-state version, as well as the floor plate. Looking forward to getting it.
#430
Thanks for the response. Sorry, I should have been more clear. I wasn't suggesting that convertibles be excluded, unless it's proven that it won't work on them. I don't think there's any reason why this system won't work on the convertible - other than removing or replacing the stamped tunnel brace, which many owners discard anyway.
#432
#435
#437
Alright, so I did ask the vendor to cancel my order. But it turns out they had sent it out a day or two before I contacted them yet again. That day I contacted them to cancel the order was the day before it showed up.
Since I have a long trip coming up for Thanksgiving, I decided this last weekend was when the exhaust should go in. Yesterday, PsychoSid and I put it in. Overall, I'm pleased with the fitment. We fought it hard to get the over the axle portion to not touch the heat shield under the fuel tank. But that was partly our fault... Sid kept trying to pull the whole system to the back of the car, when really we had to push it forward to get the hump off the shield.
Since we mated it to 3" collectors on long tubes, we had to work from the back to the front (opposite of Hooker instructions). At the front, we didn't use either of their bung'd pipes. We used a 3"x2.5" reducer from eBay, but we had to go to the parts store and throw some carbon steel on the header side for a slip fit. I hate that we had to do that, but we had to finish.
It's ridiculous quiet compared with my 3" true duals dumped with Magnaflow bullets, pretty much what I was aiming for. I'll be logging AFR the next few days to make adjustments, but watching the gauge, I haven't seen the significant difference I was expecting to see with a smaller exhaust on a 383 HCI car.
7 weeks was just ridiculous, but the kit was very complete and I'm pleased with the fitment. Thanks Toddoky, for tolerating a ticked off customer, lol...
Oh, and I took video before and after but I haven't looked at it yet. I'll post it when I remember to get it off the camera.
#438
I did get it, and I do not have it installed yet. Had to replace my camshaft which set me back a few weeks. Cam should be here end of week or beginning of next. I'll have it back together in about a week or two after that. Mine will be HCI with long tubes and spun metallic cats. I'll be sure to get a video up to add to the list of variations in setup.
#439
#440
