Ditching the lid
Old Jun 15, 2015 | 09:46 AM
HISS's Avatar
Default Ditching the lid
I currently have the FTP 104 lid setup on my z28. I'm thinking of ditching it in favor of something that goes over the core support and behind the front bumper. Anyone done this, btw I have no hood clearance issues. Pics would be a plus.
Old Jun 15, 2015 | 10:02 AM
Rise of the Phoenix's Avatar
https://ls1tech.com/forums/generatio...ke-system.html
Is this what you are talking about?
Old Jun 15, 2015 | 10:20 AM
high n dry's Avatar
That's a bad *** set up. I may do this myself...
Old Jun 15, 2015 | 10:42 AM
HISS's Avatar
Similar. But specifically someone who has done it over the core support while keeping the a/c in tact.
Old Jun 15, 2015 | 01:22 PM
SCott5's Avatar
You could run it off to the side like Martin@tick used to have when he was a nitrous car
Old Jun 15, 2015 | 01:33 PM
HISS's Avatar
I could but I have a race style cowl, and I don't mind ditching the washer tank, plus I have a small tube upper bumper support.
Old Jun 15, 2015 | 02:54 PM
Majestic9C1's Avatar
can always try using a corvette ram air setup
Old Jun 15, 2015 | 03:37 PM
You think there'd be room? What size tubing are you planning to run?
Old Jun 15, 2015 | 04:05 PM
HISS's Avatar
I'm almost positive there is enough room. If not I can notch the front of the core support. I have a race weight hood so the cowl is pretty much unobstructed. 4" tubing.
Old Jun 17, 2015 | 11:22 AM
HISS's Avatar
Surely someone has done this.
Old Jun 29, 2015 | 12:50 PM
HISS, what's the consensus? I messed around yesterday measuring and trying to figure out if it can be done with keeping air, and I just don't think it's possible.
Old Jun 29, 2015 | 05:53 PM
MR_M's Avatar
I have done this and retained a/c. You have to cut into your radiator core support aggressively to achieve this.
I used 4" tubing at the license plate opening smoothly merging with 3.5" piping coming up through the radiator support. Both were 75 degree pieces. Pretty tight fit. I have a velocity stack with an inline filter up front as well.
Edit*
If it wasn't obvious before, you need to ditch your washer fluid tank and crash support. Or cut it up, that would be a pita. I had to make new hood latch supports because the hood flutter, on top of having to slam it to get it to latch.
Old Jun 29, 2015 | 06:57 PM
Zmg00camaross's Avatar
Screw AC lol.
Old Jun 30, 2015 | 08:52 AM
HISS's Avatar
Definitely possible. Like was stated before lose the washer tank, and hood latch, as well as notching the core support, and either cutting or replaceing the bumper support with a tubular piece.
Old Jun 30, 2015 | 10:00 AM
So you going to do it? If you do, post up progress pics.
Old Jun 30, 2015 | 01:08 PM
HISS's Avatar
If I end up finishing the car I will. I'm kinda at a crossroads where I feel irresponsible for dumping money into the car......so there's that. But I sold the lid in preparation to do it. I will definitely update my build thread if and when I do it. Building the motor will have to come first.
