Speed Engineering True Dual Exhaust Kits!!
Old 07-27-2018, 10:31 AM
  #921
KCS
Moderator
KCS's Avatar
I went ahead and bit the bullet last night on the Speed Engineering 1-7/8” headers and the over the axle true duals. They’ll be replacing a set of OBX 1-3/4” headers, ORY, and SLP Loudmouth. Looking forward to getting rid of that rasp!
Old 07-27-2018, 12:31 PM
  #922
Bspeck82's Avatar
Got a set of spintechs welded to my SE dumped duals. It sounds way better than those bullets. Here is a short idle video of it now. Couldn't rev it too high because my elderly neighbor was watching. Drone is at around 1700 RPMs 40ish MPH and cruising 45 and 70MPH it is nice and quiet. Much better tone than before. Id wager this is the best sounding LS1 I have heard in person.
Old 07-27-2018, 12:39 PM
  #923
5.7stroker's Avatar
Originally Posted by Bspeck82
Got a set of spintechs welded to my SE dumped duals. It sounds way better than those bullets. Here is a short idle video of it now. Couldn't rev it too high because my elderly neighbor was watching. Drone is at around 1700 RPMs 40ish MPH and cruising 45 and 70MPH it is nice and quiet. Much better tone than before. Id wager this is the best sounding LS1 I have heard in person. SE True Dual Dumped Spintechs
Perhaps the best sounding on a true dual application, but you may want to give a listen to post #29 in the link below before reaching into your wallet:
https://ls1tech.com/forums/generation-iii-external-engine/1894664-my-new-exhaust-setup-dual-low-profile-cutouts.html
Old 07-30-2018, 04:08 PM
  #924
micbegz28's Avatar
Not knocking SE at all, bc im the idiot thats trying to make it work. but i can say that SE Over the axle Duals, MWC Chassis mount TQ arm, and a car on coil overs are NOT a good mix.
Old 07-31-2018, 08:00 AM
  #925
HioSSilver's Avatar
Sounds goid bspeck. I can tell you i miss the simplicity of my td dumps for working on the car. But i do like it exiting the back of the car now.
Old 07-31-2018, 08:53 AM
  #926
big hammer's Avatar
The best sounding dumps I’ve heard were the phab 3” dumps. The SE is raspier but I also like it coming out the back better
Old 07-31-2018, 09:35 AM
  #927
Full-Force's Avatar
That sounds amazing. It would never work on a lowered car though.
Old 08-01-2018, 11:53 PM
  #928
Bspeck82's Avatar
Probably not. If you were lowered what I would do is I'd build a custom 3" y with good merge into a 4" pipe over the axle into your muffler of choice with dual 3" tailpipes.
Old 08-02-2018, 12:50 AM
  #929
jaxcam02's Avatar
Love my kit. Had the shop Fab up my CME to it. It makes me Everytime I drive.
Old 08-03-2018, 07:23 AM
  #930
HioSSilver's Avatar
I like the center exit
Old 08-10-2018, 03:58 AM
  #931
slikrider20's Avatar
Any word on people using this on an lt1?
Old 08-10-2018, 09:18 AM
  #932
trilkb's Avatar
Lt1's sound so much better then ls1's if you ask me. I loved a few exhausts on my 2 lt1 cars and hate my ls1 car. Just sounds like junk mixed with crap. All ls1's seem to do is drone or rasp, or be too quiet lol.
Id bet you could make it work, the dumped duals for sure, but unless you can cut and weld id take it to an exhaust shop.
For people facing the rasp/drone problem, how does just a standard magnaflow cat back do?
Old 08-13-2018, 12:13 PM
  #933
micbegz28's Avatar
SE Long Tubes
SE True Duals
MWC True Dual Torque Arm X member
Strange Coil Overs in front
H&R lowering springs in rear.
Old 08-13-2018, 01:48 PM
  #934
pressureprows6's Avatar
Magnaflow cat back sounds like a stock mufflered exhaust compared to these things....Ive had both.
Old 08-13-2018, 02:30 PM
  #935
5.7stroker's Avatar
A magnaflow catback with 1 chambered magnaflow and 2 magnaflow bullets is still 67 db and that is with a cat in the I pipe. These cars with a cam are loud as hell and nobody on the streets wants any part of it. Everyone is always talking about dual over a Y pipe because of Y pipe restrictions but what does a Y pipe merge restriction matter when you have low profile cutouts before the merge?
Old 08-13-2018, 04:50 PM
  #936
jaxcam02's Avatar
Boooooring. But in all seriousness. On a daily maybe you have a point but for me I didn't want electric cutouts for another thing to possibly fail. No potential failure involved with dual tubes and I'm not getting on the ground to remove manual cutouts.
And the y pipe I had prior to the dual were 3 inch tubing but had to step down to 2 3/4 pipe on the SLP catback. I could never get a good deal with any clamp used. Leaked at that point continuously.
Old 08-13-2018, 05:03 PM
  #937
5.7stroker's Avatar
Boring is not having the ability to change the sound of the exhaust. I live an hour from the guy's shop so if the cutouts fail it's easy for me to replace. There's nothing like pressing a button and making your car wake the dead as those cutouts open, causing Harley owners to wonder wtf just happened. Then you pull in your garage with them closed without pissing off your neighbors. The issue I see with only true dual is that they are loud as hell unless you quiet them down but then you just defeated the purpose of true dual. Those cutouts are the solution.
Old 08-13-2018, 08:27 PM
  #938
jaxcam02's Avatar
To each their own. It's not my DD so the duals make it exactly what I want. I don't want it to ever sound quiet and reserved. I guess my neighbors are just cooler than yours.
Old 08-13-2018, 08:36 PM
  #939
5.7stroker's Avatar
I wouldn't know how cool my neighbors are... I never pulled in with open cutouts to find out. Might just have to do it and see.
Old 08-13-2018, 08:41 PM
  #940
jaxcam02's Avatar
Do it. You know you wanna lol
Quick Reply: Speed Engineering True Dual Exhaust Kits!!
