Belts shredded -- is that common?
Is there something inherently unsuitable about the F-body FEAD layout that does not lend itself to high engine speed? That style best fits my chassis but I might be able to fit a Corvette LS1 or LS3 FEAD if needed.
Is there a better replacement power steering pulley out there? This one seems like a cheap piece of junk.
I see my p/s shaft is 0.75" diameter. Is that standard F body size or is there a mix of 0.75" and 0.66" shaft diameters?
* Ditched the LS1 belt tensioner. Rim is short and belt can throw on engine decel. LS2 tensioner pulley has taller rim and that can be used. Although, I skipped over that too and installed the Katech manual tensioner. The belt tension will relax in the first few minutes of running due to belt seating in the pulley grooves, so need to run the engine for a few minutes and then set the belt tension again. That'll get your manual belt tensioner dialed in perfect. Keep your eye on it though because it doesn't self adjust.
* Ditched the stock plastic power steering pulley and installed a Turn One pulley.
* 10% under drive crank pulley. Needed to keep the power steering pump speed within allowable max limits of 7000 continuous and 7500 rpm intermittent.
* Turn One power steering pump. Stock pump overheats the fluid and burps fluid, even on the street. Stock pump flows a grossly excessive amount of fluid as it speeds up, and the majority of fluid is bypassed and return to tank unused. The constant pressurizing, bypassing, re-pressurizing causes temperature rise and the fluid overheats. Fluid burps out the cap when reservoir pressure exceeds 20 psi. Turn One pump reduces the volume to fix this problem.
* ATI damper with 66 rubbers. I think the catalog F-body damper is 40 durometer rubbers. Need to special order with higher durometer rubbers appropriate for your power level (vibration increases with more power).
The rim of my stock plastic pulley broke. It had to be replaced.
The power steering reservoir burped fluid regularly. It's a common issue with F-body cars.
