oil filter wont thread
Old Aug 25, 2018 | 08:36 PM
badamn's Avatar
Default oil filter wont thread
I bought a new oil pan from tick performance but now my old filter wont thread on,iy's too small? help please!
Old Aug 25, 2018 | 09:08 PM
RB04Av's Avatar
There's 2 sizes of adapters. THey changed over in some year or other. I think it was in the late 00s but I'm not sure.
No biggie though, the whole adapter just unscrews from out of the pan. It's like a 22mm hex or thereabouts. Just take the one out of your old pan and put it in the new one.
Or, look up the filter for a 2014 truck or some such, and see if the filter is different from the one you've been using, and use that one instead.
Old Aug 25, 2018 | 11:40 PM
sjsingle1's Avatar
its a 1/2 hex...for the adapter.....bought a allen wrench just for the occasion ...22mm may work...IDK
Old Aug 26, 2018 | 12:21 AM
8.Lug's Avatar
You don’t use your stock filter size anymore, you use whichever filter is for the pan. It should be listed in the instruction manual.
Old Aug 26, 2018 | 01:07 AM
badamn's Avatar
thanks for the responses, i dont have the old oil pan anymore anyway,i tossed that thing.But im thinking it might be a 22m 1.50 filter?
Old Aug 26, 2018 | 07:46 AM
8.Lug's Avatar
I don’t know why you keep asking here. Look at the instruction manual for the pan or ask Tick.
Old Aug 26, 2018 | 07:54 AM
01ssreda4's Avatar
I'm pretty sure most GMs have moved to the newer style filter around the time the Hummer h3 came out?
Old Aug 26, 2018 | 08:04 AM
RB04Av's Avatar
You're right sjsingle, I'm not sure what I was thinking of that's 22mm... the adapter has an allen in the center.
But yeah, either change the adapter, or use the later-model filter. Just look it up for a newer vehicle. No need in outsmarting yourself over what thread it is.
Old Aug 26, 2018 | 02:05 PM
99 Black Bird T/A's Avatar
One easy fix is to get an oil filter for a 2015 SS Camaro, that will be the new oil filter thread size and should ft. I had the same issue with a new oil pan last year.
