Need help with truck alternator mod
Old Mar 7, 2020 | 03:00 PM
RONIN LSX's Avatar
Default Need help with truck alternator mod
I need to replace my alternator in my 02 TA.
A friend was going to install it for me and suggested that I get the ACDelco 334-2529 truck alternator, but he completely sold me out and now I'm stuck, because I sure as heck, don't know anything about the truck alternator mod.
Is there anything done different, when using the truck alternator, or is everything the same?
This is the alternator I bought
https://www.amazon.com/gp/product/B002QVHN7O/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1 https://www.amazon.com/gp/product/B002QVHN7O/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
Old Mar 7, 2020 | 05:06 PM
RB04Av's Avatar
That's the low output truck alt... ???
Old Mar 7, 2020 | 06:57 PM
ddnspider's Avatar
It should bolt right up but the pulley may be farther away than an ls1 alternator requiring a belt about an inch longer.
Old Mar 7, 2020 | 10:48 PM
sjsingle1's Avatar
you may have to bend the PS lines a bit....longer belt maybe.....not hard at all
maybe our resident truck alt guru......pooter.....will chime in
Old Mar 10, 2020 | 06:12 PM
RONIN LSX's Avatar
Low, as opposed to what? It's the 145a version.
Old Mar 10, 2020 | 06:13 PM
RONIN LSX's Avatar
Isn't this the one that everyone suggests?
Old Mar 10, 2020 | 06:26 PM
Floorman279's Avatar
ur best bet is an eBay 4 pin used alt. pooter said he always had bad luck with 99.9 percent if not 100 percent of the remans regardless of brand.
calling it a truck alt mod doesn't make any sense to me since ur not modding anything, ur literally removing the alt and putting the truck one in. done on 2 different cars, it just fits more snug and didn't require a new belt
Old Mar 10, 2020 | 06:27 PM
yes 145 amp
Old Mar 11, 2020 | 08:27 AM
00cls1camaross's Avatar
I bought the 335-1092 see here: https://www.rockauto.com/en/moreinfo...67826&jsn=1794
I can confirm this was plug and play for my 2000 camaro. The 335-1092 is for the escalades that were 2002 and earlier.
The 334-2529A is for trucks that are newer than 2003. https://www.rockauto.com/en/moreinfo...17150&jsn=1790
They appear to both be 4 pin and 145 amp.The only difference is the location of the plug which appear to be at a different clocked location. I don't see why yours wouldnt work. Pooter's thread notes to use the 2003-2004 They both are of the AD244 family.
Here is pooter's old thread
https://ls1tech.com/forums/generatio...ilure-s-3.html
Good luck, let me know if you have any other questions
Old Mar 11, 2020 | 12:51 PM
ddnspider's Avatar
Ive been a fan of DB Alternators. Good prices and the quality seems good and they come in all sorts of outputs.
