Ultimate ALL OUT bolt-ons??
Old Oct 27, 2023 | 10:01 PM
Magnet's Avatar
Default Ultimate ALL OUT bolt-ons??
Trying to push my car with bolt ons only…. What is the No limit bolt ons? Stock internal 346 Ls1
What Im currently thinking but open for input:
1 7/8 wrapped longtube headers
True duals/dumps
Mamo ported 102mm fast intake/TB
Chrs1313 pro stock ram air
SLP under drive pulley
Meziere electric water pump
GZ Motorsports vacuum pump
Proper tune
NGK 55
MSD wires
Up for consideration/discussion:
- aftermarket/upgraded coils
- e85
other…?
Old Oct 27, 2023 | 11:30 PM
98CayenneT/A's Avatar
If that's your list, Google max effert ls1....
Old Oct 28, 2023 | 11:05 AM
If your a manual, a lightweight clutch. If your an auto, a big stall. Are you opposed to opening up the engine?
Old Oct 28, 2023 | 01:27 PM
Magnet's Avatar
Only bolt-ons. Clearly heads/cam etc can push power. I’m looking for options that fall into “stock internal” as I’m working on a purpose built car to go 10s stock internal.
It’s an auto and I’m aware of the stall etc, but I’m making sure I’m not overlooking any power adders that would fall into the “stock internal” category as described above. The engine can’t be opened up, or at least can’t be upgraded in any way.
Old Oct 28, 2023 | 03:32 PM
Racing class rules??
Old Oct 28, 2023 | 03:46 PM
LS1 TJ's Avatar
Maybe nitrous?
Old Oct 28, 2023 | 04:08 PM
ddnspider's Avatar
All depends on who you ask. People on here for decades have claimed they had bolt ons when they added roller rockers, crank scraper, etc. Everyone definition is different.
Old Oct 28, 2023 | 04:58 PM
Magnet's Avatar
Not really. It’s a just a “bragging rights” thing. My 6spd is the fastest stock internal 6spd ever at 11.1 and want to push my auto faster as well. “Stock internal” is a class I suppose but only one made up online
Originally Posted by LS1 TJ
Maybe nitrous?
Lol no power adders.
this is probably true, but the stock internal guys are a pretty stand up crowd overall and I’ve gone fast myself and know what’s done to the cars so believe most of the cars to be real/not cheating. At this point there’s also nothing to gain. Back in the day certain shops might have benefited from have certain records but no one cares anymore on these cars 😂
back on topic… does anyone have any other thoughts? Experience with e85 on stockish motor? I plan to run a short belt routed so it doesn’t turn the power steering as well.
Old Oct 28, 2023 | 05:02 PM
TrendSetter's Avatar
With stock cam you’re pretty limited. Throw it on a dyno so you know where peak power is and get gears and converter that holds you right in that rpm range the whole pass.
Use the shortest(lightest) tire that will hook. This will tie into your gears and converter calcs.
lightweight everything including oils
I’m surprised there’s any real unopened ls1s left.
Old Oct 28, 2023 | 05:37 PM
Magnet's Avatar
yea I’m working on the drivetrain/chassis as well, just specifically looking for input in the power side any any experience with things like e85 since I don’t have any etc
plenty of unopened cars although I’m sure quite a few less then 10-15 years ago😂
Everyone forgets how stout the original Ls1 a were imo. All obsessed with turbo 5.3s 🥴
Old Oct 28, 2023 | 07:26 PM
What about weight reduction? Are any in this crowd removing serious weight?
Old Oct 28, 2023 | 07:35 PM
Bspeck82's Avatar
Idk how you add power without modifying the motor....maybe a ssra ram air induction box. Free up HP with 25% under drive pulley, or delete power steering and AC. Thinner felpro head gasket? Electric water pump.
Old Oct 28, 2023 | 07:38 PM
Q16 or m1
Old Oct 28, 2023 | 07:56 PM
Magnet's Avatar
did ya read my post? Ram air already accounted for, under drive pulley already accounted for, already running a short belt to avoid power steering. AC already removed. Thinner head gasket not allowed. Electric water pump already accounted for.
Q16 or m1
I don’t know much about these. Any experience? I’m open to different fuels. Not going nitro etc but something like this 🤷🏻‍♂️
Old Oct 28, 2023 | 08:07 PM
Magnet's Avatar
I’m covering this separately. This is the external section aka bolt-on section which is why I posted here looking for help/insight for that specifically…
To answer yes, of course we are removing weight.
Old Oct 28, 2023 | 08:54 PM
LS1 TJ's Avatar
Stock gearing and rear end? Are sticky rear tires going to blow up the stock rear end?
Old Oct 28, 2023 | 09:42 PM
Magnet's Avatar
why does everyone want to talk about everything except the actual topic 😂
10bolt can hold more then most will let on. They won’t hold long term with sticky tires but can do just fine for a couple times a year track trip and then street driving with normal tires.
My car has a stock rear with 3.42 gear out of a 6speed. I have an extra waiting if it breaks 🤞🏻
Old Oct 28, 2023 | 10:14 PM
Why does everyone want to talk about everything except the actual topic?😂
Because you've pretty much tapped out on external engine mods, and are trying to help with any other possibilities.
Old Oct 28, 2023 | 10:21 PM
Magnet's Avatar
fair enough, but that’s what I’m looking to confirm. Looking for folks that know something I don’t.
For example, no one has answered about e85 or other higher octane fuels yet. Would love any input with someone that has experience/knowledge. Same thing with aftermarket coils/truck coils etc
Old Oct 29, 2023 | 07:00 AM
q16 is an oxygenated fuel. it will make more power than c16. m1 also will make more power but im not sure which will make more. q16 is a gasoline so it wont require the large fuel flow that m1 will.
your own stipulation of untouched heads and stock cam basically limit what you can do. your only options are what intake and exhaust gets bolted on.
if you said 'stock displacement' or 'stock lift camshaft' then you can start getting creative but unopened engine is an unopened engine.
