Turn signal on solid???!!
Ok like the subject says, my turn signal only comes on solid(does not flash)... both sides. Trying to brainstorm what to look for tomorrow so any help would be appreciated. Right now all I can think of is the turn signal is controlled by a relay/fuse that might have gone bad. If that might be the case anyone know where the relay/fuse is? ...in the ignition wiring harness?
Any help is appreciated.
Dave
I just installed MAC midlength headers and the problem showed up after. Anything I could have hit or some wire that could be getting burned on the header to cause this?
Dave
Sounds like your flasher is bad. It should be a little black box or a little round silver looking thing under the dashboard up close to the firewall. They sell them at auto parts stores for like 5 bucks. Looks almost like a relay.
yup, im pretty sure its the bulb(s) on the side that it stays solid, just check them bc i had this problem a few times, my bulbs melted the plastic and water leaked and blah blah blah =)
Turn on your 4-ways & check if all the bulbs work. Then R&R that flasher with your turn signals (you can hear if clicking when the flasher is running to find it). At this point you should know what it isn't, and most likely what it is. (meaning if one of those steps didn't isolate the problem, start checking the wiring)
I replaced the flasher and that worked, thanks for the help everyone. Took me a second to find it since it was clipped bhind the metal to the right of the steering column. Replaced it with a similar one from autozone that the dude said would work and it does. Also it is much more quiet.
Dave
![The Patriot !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_patriot.gif)
Dave
