Will pacesetters work with lightweight k-members?
Old Oct 20, 2004 | 02:47 PM
black_knight's Avatar
Default Will pacesetters work with lightweight k-members?
Here's an odd question: I have pacesetters and had to notch my k-member (I have the old ones, I guess). What if I buy a lightweight chromemoly k-member? Do I have to notch that, too, or do they generally fit with the old pacesetters?
Are the lightweight ones generally less bulky? I still get a little banging every now and then, so I wonder if I could fix a problem and also lighten my car at the same time...
Anyone try THAT combo?
Old Oct 20, 2004 | 02:54 PM
777's Avatar
777
oh i'm sure you will have no clearance problems...chromoly especially should give you ALOT more room around in there...that is half thier purpose...so you can have more room for turbos or headers
Old Oct 20, 2004 | 07:38 PM
Larry's Avatar
My PA cleared my Pacesetter with room to spare on the drivers side. Slight grinding required on the passenger.
Old Oct 20, 2004 | 08:16 PM
Larry, excuse my ignorance, but what is a "PA?"
Old Oct 20, 2004 | 08:33 PM
WILWAXU's Avatar
PA racing >>-->
They build/sell tubular k-members.
Old Oct 20, 2004 | 08:41 PM
jimmyblue's Avatar
Moderator
In general K-members relieve the area around the
bottom of the block but there are some exceptions,
my BMR has corners on some of the weldment that
stick in further than the factory stamping (which is
unfortunately exactly where my Random Tech high
flow catted Y-pipe cats wanted to be).
I think it all comes down to cases, though, and I can't
ever recall seeing anyone beef about real headers and
aftermarket K-members.
Old Oct 20, 2004 | 08:59 PM
jrp's Avatar
jrp
SN95 Director
i dont see how you couldnt clear this
https://ls1tech.com/forums/showpost....7&postcount=19
Old Oct 21, 2004 | 07:32 AM
Larry's Avatar
This is where I had to grind on the passenger side to make sure the header did not hit the K member. The engine torques this direction so even though there was a slight clearance with engine torque it would have hit. Only took a couple minutes to give it the extra clearance I felt it needed.
Attached Thumbnails Will pacesetters work with lightweight k-members?-mvc-018s.jpg
Old Oct 21, 2004 | 08:20 AM
So, the verdict seems to be: "sometimes!"
Larry: That's weird; I had to grind the driver's side on my stock k-member.
jimmyblue's Avatar
Moderator
I marked on jrp's K-member pic and on a BMR one
where I ran into the bind. Only about half an inch
too far in for the RT cats but I was unwilling to hog
it back, because it's structural for the rear mounting
bolt.
Attached Thumbnails Will pacesetters work with lightweight k-members?-rearmount_x.jpg   Will pacesetters work with lightweight k-members?-jrp_k_member.jpg
Old Oct 21, 2004 | 08:29 AM
Jimmy,
Was that problem entirely due to the location of your cats?
Old Oct 21, 2004 | 08:58 AM
jimmyblue's Avatar
Moderator
I believe so, they are a lot fatter than the stockers,
I guess barely fit with the stock K-member and that
one "ear" just screwed me up. If you have an inch or
so clearance against the stocker it probably won't
hit you. It's just different than "normal" in that spot
and my particular pieces interfered.
Old Oct 21, 2004 | 05:24 PM
critter's Avatar
I have the BMR K-Member and my Pacesetters have a lot of clearance - much more than with the stock K-Member.
Old Oct 21, 2004 | 06:05 PM
Hmmm, so in my particular case, it sounds like the BMR is a good bet...
