those with TSP duals
Old Apr 11, 2005 | 10:52 AM
jrp's Avatar
jrp
SN95 Director
Default those with TSP duals
can yall do me a favor and take a pic of your clearance from the X pipe to the torque arm and how high your bullets tuck up.
Old Apr 11, 2005 | 11:22 AM
Stryker's Avatar
what clearance lol.. ill try to get a pick but i had to sacrafice ground clearance for any torque arm clearance. so anytime i have someone ride with me its a common thing to bottom out under the most minimal bumps.
Old Apr 11, 2005 | 11:25 AM
jrp's Avatar
jrp
SN95 Director
hence the reason for my post . im wondering if im stuck with loosing ground clearance or loosing tq arm clearance. i dont got dick for ground clearance right now and im trying to rework the setup to see what i can do.
Old Apr 11, 2005 | 11:34 AM
Stryker's Avatar
yea luckily i have stock ride height still or imo it would be a worthless attempt. unless somehow you could rework how the tubing crossed by the t.a. i think im gonna attempt moving it over when i finish it off to the back of the car
Old Apr 11, 2005 | 11:36 AM
kraut187's Avatar
I have the same issues with my setup, that thing hangs damn low. PLEASE let us know if you find a way to tuck them up better, I have to keep mine off the fuel lines as it is right now.
Old Apr 11, 2005 | 08:27 PM
4.6gt-2-ls1ta's Avatar
should have bought Lane's duals.LOL mine tuck up nice and tight and even with people and stuff in the back of mine I have never had the torque arm hit and my car sits low. But what you might wanna look at is how the angle of the pipe from the X to the muffler is then maybe you can adjust the bullets to get your clearance.
Old Apr 11, 2005 | 08:53 PM
kpowr82's Avatar
Here ya go JRP. Sorry if they are too small. I don't have these on anymore cause of my ground clearance issues. I've got the Hooker Catback, and hopefully once I get my poly trans mount, I'll be completely happy with this ORY setup.
Attached Thumbnails those with TSP duals-615104_25.jpg   those with TSP duals-615104_26.jpg
Old Apr 11, 2005 | 08:55 PM
kpowr82's Avatar
and yes, those are SLP boxed SFC's. I can't believe my muffs hang lower than them. BTW, I have the sweet thunder chambered mufflers. If I still had bullets...
Old Apr 11, 2005 | 09:25 PM
shep28's Avatar
My mufflers are fine. It is the driver side section behind the collector that is lowest. To get my x positioned higher, I bought a torque arm and banged in my drive shaft tunnel in a few spots. This gave my the clearance that I needed in the back.
Old Apr 11, 2005 | 09:27 PM
shep28's Avatar
Where does the top of a beer can come to when you place it under the muffler? Under the section directly behind your header collector clamp?
Old Apr 11, 2005 | 09:45 PM
Raise's Avatar
hey jerami, y dont u run a couple of reducers off the back of the x pipe and run 2.5" pipes back with maybe some smaller diameter mufflers. i think that would cure both of your problems.....better ground clearance and torque arm clearance. im runnin a full 2.5" x pipe with sweet thunder mufflers and im gonna bang the **** outta my floorboard so everything will tuck up nice. i believe the sweet thunder mufflers are 3" diameter. im installing everything tomorrow...i cant wait!! i will post some pics so yall can check out my clearance. anyway, good luck jerami
Old Apr 11, 2005 | 09:48 PM
jrp's Avatar
jrp
SN95 Director
Originally Posted by Wickid Z
hey jerami, y dont u run a couple of reducers off the back of the x pipe and run 2.5" pipes back with maybe some smaller diameter mufflers. im runnin 2.5" x pipe with sweet thunder mufflers and im gonna bang the **** outta my floorboard so everything will tuck up nice. i think that would cure both of your problems.....better ground clearance and torque arm clearance.
the clearance issue is the x-pipe. there isnt enough clearance from the tq arm to pivot the bullets up any higher. been looking to get a new tq arm but i dont know how much extra clearance i'll have. right now the bullets are like 2 inches off the ground with the x-pipe touching the tq arm.
Old Apr 11, 2005 | 09:52 PM
86 IROC's Avatar
Old Apr 11, 2005 | 09:53 PM
kpowr82's Avatar
Can you post up some pics? Are you lowered?
I know I've already said this in another post of yours, but are you sure the x is on the right way? Have you tried flipping it to see if you get better clearance?
Man, this is exactly why I switched back to my ORY setup. I'd rather deal with a banging y-pipe than the poor clearance of TD's on a lowered car.
Old Apr 11, 2005 | 09:56 PM
kpowr82's Avatar
If your x is on the wrong way, one of your bullets will not clear the torque arm.
Old Apr 11, 2005 | 11:22 PM
jj_z28's Avatar
Here's mine w/ Eibach sportlines. I rarely scrapes believe it or not. It has been slightly reworked since the pics were taken. I have about a finger between my TQ arm and X pipe, maybe little less.
Old Apr 11, 2005 | 11:52 PM
jrp's Avatar
jrp
SN95 Director
i've got plenty of room to push my bullets up its just that the x hits the tq arm before i can really get the bullets turcked.
mine looks like jj's but im at stock ride height. i've got the X fabbed up like 86_Iroc with the angle of the X pointed up.
pffftt, guess im just stuck with shitty ground clearance
Old Apr 11, 2005 | 11:56 PM
JRP if you wanna see some pics of mine I can send them to you they might help you find a way to fix yours. I was gonna attach them but they are to large. if you want them let me know.
Old Apr 12, 2005 | 12:05 AM
jrp's Avatar
jrp
SN95 Director
send them to me at layzie3@juno.com if that one doesnt work send them to khadafi3@juno.com
thanks
Old Apr 12, 2005 | 12:17 AM
MUSTANGEATER's Avatar
Jerami,
What torque arm you running? I'm having Billingsley Fab one up to match my dual exhaust. However I know a lot of guys are going with the Alston to fit the Duals.
Floyd.
