How to get TB wide open
Itried to adjust the cable going to the TB & when I start it it goes to about 2000 rpm's.
goes to dead center when you work it by hand.
Next loosen and pull snug the cable adjusters in
the engine compartment so there is no cable
slack there.
If you still can't get it fully open, make sure you
don't have too much floor mat bunched up under
it and then see how much slack you have in the
non-adjustable pedal cable. That was almost 1"
on mine, I had to cobble up a long spacer with
vacuum hose, a slitted washer and some heat
shrink tubing.
If you don't have TC or CC, then you have to make a spacer like jimmyblue suggested. Hope you have the adjustable cable!
Anyone else.
I just did what jet-black said & it did the same thing. It would'nt return to closed therfor idle is high on start.
So I backed the cable off a bit & it idles better but the blade could open another 3/4''. Its 3/4" away from the bump stop.
. pedal to the TCS pulley cluster is non-adjustable.
That's why you have to add a spacer, if none of
the other things pan out.
The adjustable cables, you want to make snug
with the pedal at rest, just short of actually
moving the throttle blade. You do not want them
to be in tension, that will jack the blade open and
mess with the idle. You just don't want slop.
. I took it to my pontiac dealership and it was fixed for about $80. It took them about 1.5 hours.
