FAST 90mm problem ??
Old Oct 21, 2005 | 10:26 AM
oOoLy's Avatar
Default FAST 90mm problem ??
How can i fix the FAST 90mm RPM ???
Old Oct 21, 2005 | 10:41 PM
WILWAXU's Avatar
Do you have an intake leak?
Old Oct 21, 2005 | 11:07 PM
SUX2BU's Avatar
TB or intake? how bout some details on the problem.
Old Oct 22, 2005 | 11:39 AM
oOoLy's Avatar
I think the problem in the TB ??
Old Oct 22, 2005 | 12:34 PM
Bill's 02 Z-28 SS's Avatar
I agree with the posting above What problem are you talking about?
Bill
Old Oct 22, 2005 | 01:41 PM
oOoLy's Avatar
The problem in the RPM ( the rpm go to high RPM suddenly )
Old Oct 22, 2005 | 01:42 PM
Zymosis's Avatar
Ha, I'm assuming he has a leak?
Old Oct 22, 2005 | 02:23 PM
TAQuickness's Avatar
Hey, what's my problem?
!hijack
Old Oct 28, 2005 | 07:50 PM
oOoLy's Avatar
When i drive the car and every thing is ok suddenly the RPM stop @4000RPM and go up how can i fix my TB ??
Old Oct 28, 2005 | 08:07 PM
SUX2BU's Avatar
throw it in the garbage. FAST tb's suck ***.
Old Oct 28, 2005 | 09:05 PM
oOoLy's Avatar
I know there is a drill mod but i don't know how to do it ??
Old Oct 28, 2005 | 10:22 PM
SUX2BU's Avatar
That won't help. you have to send it back to FAST the first throttle bodies they made were paper weights. i don't know if the new ones are any good but good luck.
Old Oct 28, 2005 | 10:47 PM
LSUxBlake's Avatar
I had one of the "fixed" ones on my car for about a week. I loved having to sit at redlights and tap the gas trying to get it to come down from 4500rpm. Got rid of it and bought a TPIS (this was before NW came out) and couldn't be happier, no problems at all.
Old Oct 29, 2005 | 04:47 AM
you might do what ever you can and pick up a Nick Williams 90.
Old Oct 29, 2005 | 05:20 AM
Mike K.'s Avatar
The fixes always were,
1. machine a flat spot to the throttle cam so the stop bolt does not slip.
2. wind the spring tight as ****
3. was the inside of the tb with some real smoot ****.
4. Try to find where it is getting hung up at and use a dremel to clean up the area or
widen it a tad,
careful with the dremel though , to much and you will idle high forever.
