pacesetters & extentions?!
Old Oct 23, 2005 | 01:44 PM
prostock_bigblock's Avatar
Default pacesetters & extentions?!
Just order the pacesetters coated . Do i still need to order the O2 extentions or not?
Old Oct 23, 2005 | 01:45 PM
CamaroRumble's Avatar
yes...
Old Oct 23, 2005 | 02:22 PM
FatZ28's Avatar
When my friend ordered his they came with do it yourself extentions. We didnt use them though.
Old Oct 23, 2005 | 03:48 PM
FLA02TA's Avatar
Young at Byunspeed told me I could ghetto rig it with spliced wires. Would be cheaper than the ~30ish$ cost on the extension.
Old Oct 23, 2005 | 04:02 PM
00sscam's Avatar
My pacesetters came with the getto splice kit. Spend the cash and get the right stuff
Old Oct 23, 2005 | 04:23 PM
Dino98T/A's Avatar
U could also get vette o2sensors. They come with a longer wire. No getto rig or extentions.
Old Oct 23, 2005 | 04:29 PM
do you got the part no.? if not which year model plzzz?
Old Oct 23, 2005 | 04:46 PM
Ferocity02's Avatar
I got two 24" extensions for my Pacesetters, they are made by Casper.
Old Oct 23, 2005 | 04:49 PM
Speed Density's Avatar
hashtagBMW
If you orderd the LTs, i got my pacesetter coateds with o2 extensions? I dunno if anyone else did but mine came with some.
Old Oct 23, 2005 | 10:31 PM
skewba98z28's Avatar
Splicing is not ghetto if you do it right. Sorry guys electronics major here. All you need is a soldering iron, solder, some heat shrink, and a heat gun. I would trust that over a plug and play deal. Now using butt splice's, or twisting the wires and using electrical tape that is ghetto on an application like that. But to each his own.
Old Oct 24, 2005 | 12:02 AM
BriancWS6's Avatar
Agreed. With that said I didn't wanna screw with that so I bought the plug in extensions. I guess a good idea would be to get the vette O2s when you NEED new O2s, then you could sell the extensions to someone. O2 sensors aren't that cheap to just buy them for the hell of it.
Old Oct 24, 2005 | 11:47 AM
Thanks for the info guys..
Old Oct 24, 2005 | 11:57 AM
Mike2000Z28's Avatar
If you needed help here is the link for the set that I used http://www.ls1speed.com/catagory.cfm?catagory=Exhaust
Got luck on the install, I had alot of fun and loved the ORY sound. To bad the piggys didn't later that night.
Old Oct 24, 2005 | 12:10 PM
WS6FirebirdTA00's Avatar
if your o2s are old order some denso vette rear o2 sensors, its a good time to replace them if they are old plus you dnt have to deal with extensions
Old Oct 24, 2005 | 09:07 PM
00sscam's Avatar
I agree with you 100% but it has been my experience that a lot of people do not have the ability or tools or knowledge to do it the right way (IC- US NAVY) not that it is complicated or what not just some do not have the same exposure as others have had. Plug and play seams to be a lot easer for most.
Old Oct 25, 2005 | 02:13 PM
gwj's Avatar
gwj
From: Live Oak, FL - in the woods where the creatures lurk.
I agree. Folks I've known could tear down/rebuild an engine that couldn't do jack when it came to wiring/soldering.FWIW-I have electronics experience and still went with plug and play.
Old Oct 25, 2005 | 07:56 PM
Yeah that's cool. I just have the tools at my disposal. No reason to let them set there What are extensions now like $30 $40 dollars.
Old Oct 30, 2005 | 05:12 PM
FLA02TA's Avatar
PaceSetter LT's in LS1's use the square connection extension, right?
Old Oct 30, 2005 | 06:49 PM
Z28LS1camaroguy's Avatar
arent the extensions for the front O2s, just get the rear O2s deleted since you are gonna be running an offroad Y right.
Old Oct 30, 2005 | 09:04 PM
stangkiller's Avatar
yep ext's for front and sims for rear. you really don't even need them just get them deleted.
