header install gas mileage tips
Old Jan 7, 2006 | 01:23 PM
SOM98TA's Avatar
Default header install gas mileage tips
anything I can do besides change plugs/wires to get better gas mileage out of the car while I'm doing my header install..
ideas?
Old Jan 7, 2006 | 02:11 PM
Lithium's Avatar
SSU's Drunk Typing Whore
Not that I know of...
Just got to learn to drive like a ***** to get good mileage.
Old Jan 7, 2006 | 02:18 PM
camaroextra's Avatar
what is this good gas mileage that you speak of?
Old Jan 7, 2006 | 02:26 PM
taintedmeat's Avatar
I think it could be a lot worse for the power we're making. Most of us get like what, high teens around town? That's about what most minivans get while making like 1/3 the power.
Old Jan 7, 2006 | 03:34 PM
jimmyblue's Avatar
Moderator
'Vette rear O2s, these at least have a prayer of
working properly at low gas flow, lower exhaust
heat. Plus you don't have to buy extensions.
Old Jan 7, 2006 | 04:51 PM
99Hawk262's Avatar
Just put those headers on. I saw 3-4 MPG increase when my headers and TD's went on. Tripped 2300 miles across the country at an average speed of 85 and still saw 23 MPG average. Before the headers, I averaged 19-20 MPG highway. And this is low compared to a lot of the A4 guys. Some of them see over 25 MPG daily.
Old Jan 7, 2006 | 05:43 PM
davered00ss's Avatar
Moderator
Headers will give you an increase in MPG.
Old Jan 7, 2006 | 06:11 PM
BlutVonSchwachen's Avatar
Air filter, check tire psi, might as well rotate them as well while it's in the air if you havent done that in awhile. Not so much to do with the headers but a lot of people seem to forget about injector cleanings... just clean the whole intake system if you want, that will help with fuel mileage.
Old Jan 8, 2006 | 12:04 AM
Zymosis's Avatar
That, and the most important part, stay off the loud pedal. You don't have to practice your 60 foot time from every stop light.
Old Jan 8, 2006 | 01:46 AM
Larnek's Avatar
About to do the same to mine. Also going to change differential fluid while its up. Do a once around on the underbody. Wires, plugs if its time. Put that supercharger you always wanted in the rear...
Thats a filthy rumor. It IS necessary. No really.
Old Jan 8, 2006 | 07:18 AM
99Hawk262's Avatar
I thought that's what stop lights were for.
Old Jan 8, 2006 | 09:30 AM
SOM98TA's Avatar
hm.. clean injectors, change plugs, get a tune I think would help..
I'm pulling in like 11-12 mpg.. I used to get ALOT bettter
Old Jan 8, 2006 | 11:03 AM
jinxedz's Avatar
So,
Vette Rear 02's in place of front 02's on an F-Body?
Old Jan 8, 2006 | 11:41 AM
purple98haz28's Avatar
so glad i don't have an a4. i can pull like 27-28mpg all highway........ohhhhhhh 6th gear
Old Jan 8, 2006 | 05:21 PM
Originally Posted by jinxedz
So,
The post and pre cat o2's function the same. The only difference is length. Rear O2's will reach the long tube o2 bungs. I guess they produce a higher voltage for the heater so they can get the car into closed loop faster, or so I am told.
Old Jan 8, 2006 | 05:29 PM
jinxedz's Avatar
Cool,
Thanks.
