TPIS Oval LS6 and Throttle body
Do you have any idea where that info is??
https://ls1tech.com/forums/generation-iii-external-engine/432100-ls6-intake-vs-fast-lsx.html
about half-way down TPiS chimes in.
Here is a link to a scan of the article referenced at the end of the thread:
http://www.eadperformance.com/intakearticle/
I'm looking for a cheaper alternative to the Fast90/NW that doesn't sacrifice too many ponies.
Same here .. I need to check with TPIS and find out how much they are charging to do the conversion on a LS6 intake to accept a 90mm TB..I wonder if a MW 90 MM TB will work on the intake too after conversion or if only the TPIS TB will after conversion??
100-194 Billet Oval Throttle Body, 00-02 F Body, Exchange........$499.00
Core of $300
100-192 Modified LS6 Intake for Oval Port Throttle Body, Exchange........$350.00
150-192 Intake manifold core charge, LS6........$500.00
Only worth it if you send in your own LS6 and your own TB ($999). It's $1350 if you send them a TB ($1650 outright for everything), a bit more than the 90/NW90 combo.
Core of $300
What kind of pricing have you found for the MW 90 MM TB and the Fast intake
EDIT: Consider this. If you have a LS6 to begin with, $1100 for the FAST 90/90 - the $400 you'd get back selling your LS6 intake and TB, and you end up at a loss of $700. That's more pwr with room to grow at $300 less.
Thanks for the info..I have both cores..but as close as the price is I guess the fast 90 mm intake and the MW 90 MM TB is probably the way to go..especially with ability to port match the intake..
