FLP V-Flange Clamps
FLP V-Flange Clamps
The bolt on the V-clamps seem to be too short. I got it around the ORP and header, but I can't connect it <img border="0" title="" alt="[Mad]" src="gr_images/icons/mad.gif" /> Is there something i'm doing wrong?
Re: FLP V-Flange Clamps
Generally if those clamps won't close it is because the two exhaust pieces are not seated together. Try tapping the two pieces together while holding closing pressure on the clamp (or put a C clamp around the clamp to apply some pressure).
They will fit. Provided you're using the right size of course. You gotta hold the ORP tight and flush with the collector and then put on the clamp. You can kinda squeeze the clamp with one hand and wiggle the ORP with the other to get it to snug up better. Eventually you'll get a couple threads sticking out of the other side of the clamp and you can start the nut.
If you really can't get it on, try getting a long bolt to 'start' it. Once you tighten it up once, it will be fine. I've taken mine off and on and there is like 1/2" of threads showing when I do it by hand now.
Dope
Dope
all i do is take one of those big pairs of pliars and sqeeze the two ends together after i put them on easily... then i put the screws in <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
1 Post
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by DaddySS:
<strong>Generally if those clamps won't close it is because the two exhaust pieces are not seated together. Try tapping the two pieces together while holding closing pressure on the clamp (or put a C clamp around the clamp to apply some pressure).</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I'd go with this suggestion because it has worked for me. I never did like those V-band clamps.
"All Motor 9 Second club member"
I took the clamp bolts to the hardware store and got a couple of longer "starter bolts" once you get them pulled in once they are much easier. Also I sprayed mine down with WD-40 first as well as using aluminum foil to wrap around as a sealing aid. Good luck. You're gonna love'em!!!!!
James
James
LS1Tech Sponsor
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by R U A LS1:
<strong>all i do is take one of those big pairs of pliars and sqeeze the two ends together after i put them on easily... then i put the screws in <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I did the same thing <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
I just got them on today! The pliers helped a lot. Thanks for all your help, everyone <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
