Could I install a new catback myself?
If you are removing stock exhaust, you are going to need like a sawall or something along that line.
You may want to test fit all the pieces before trying to do it under the car, that way you can see if there needs to be any adjustment to the openings to get it all to fit right (it's alot easier to do on the floor, rather than trying to do it while your laying on your back underneath the car
it took me a total of about 3.5 hours to do my cat back 3 of which i spent getting the old one off
just get a sawsaw and some mettle blades and dig in for the fight
-Josh
Rick M.
I just took a quick peak under my car. It appears that I could uninstall the Dual/Dual without cutting anything...
All of you say I'd need a Sawzall or equivalent...but the D/D is "technically" a catback isn't it? Not the STOCK Catback all of you are talking about with cutting and such...
Rick M.
Have the sawzall on stand by in case you can't get it apart, and if you can get it apart, sell it and recoup some of the money you spent for the new catback
I ordered the Loudmouth II exhaust, and I went again and attempted the install myself.
As someone else said the hardest part was getting the old **** off... I wanted to remove it keeping in mind that I may want to re-install the old **** if i sell the car... So, taking it off with trying to spare everything was a task. (never touched exhaust before).
I would like to say the quality of the Loudmouth pipes were VERY good. The finish is VERY nice too. Touch it with some Mothers polish (before you install) and look out! It shines like chrome tips in no time!
Long story short. You shouldnt have a problem putting it on yourself.. My brackets ended up not cramping tight enough on the pipes, saging one side, so i had to get them welded.. (pipe thickness was too strong for the brackets. They couldnt squeeze hard enough) Plan on getting it welded in the near future!
If you have replacement rubber hangers than you can just cut off the old ones.
not that bad...getting the stock one off is the hard part
