idle issues please help
Old May 14, 2006 | 02:47 PM
stevensLS1's Avatar
Default idle issues please help
this has been going on for a while now but just got worse lately. whenever i push the clutch in the car wants to rev up and not idle down. ive got a ported throttle body on my car and ive cleaned the t.b. also there is a hole drilled in the butterfly. im thinking its a tps sensor or could the t.b be bad? not sure please help.
Old May 14, 2006 | 03:23 PM
TransAm_00's Avatar
Throttle Positioning Sensor
Old May 14, 2006 | 04:00 PM
SSilverSSurfer's Avatar
i guess its time for a 408 steven
Old May 14, 2006 | 04:08 PM
xaon's Avatar
more detailed specs on the car's setup? I'd guess that you've got a cam and such in the car and your throttle cracker/follower settings in the tune need to be tweaked.
Old May 14, 2006 | 04:24 PM
stevensLS1's Avatar
well its got an "s" cam in it and i had chuck retune the car and it was having fuel problems but he said he fixed that?
Old May 14, 2006 | 04:36 PM
xaon's Avatar
So, The car idles fine, but when driving around, you press in on the clutch and the RPM's raise up and hang (oh, somewhere 1600-2200rpm) until you come to a complete stop?
Old May 14, 2006 | 04:41 PM
TheBlurLS1's Avatar
That's what she said...
Mine does this. The RPMs hang at like 1600 or so, then drop down to idle speed when I stop. It really helps with driveability.
Mine was tuned by Chuck as well.
Old May 14, 2006 | 04:56 PM
xaon's Avatar
It sucks for driveability, and it's a common issue that is easily fixed if the tuner gives it the attention it deserves. Generally it is the throttle cracker table out of whack from the increased airflow. Sometimes the throttle follower table also needs to be tweaked.
I'd venture to say that when your car is hanging at 1600, your throttle cracker PID (in a scantool such as autotap/efilive) is sitting at ~2.5
Old May 14, 2006 | 05:03 PM
stevensLS1's Avatar
actually sometimes it doesnt idle down at all. i usually start to release the clutch then it idles down but if the car starts to move ill push the clutch back down and it idles right back up. i seem to notice it when the car is hot also.
Old May 14, 2006 | 05:15 PM
indyboom's Avatar
check your throttle cables, there adjustable
Old May 14, 2006 | 09:55 PM
Jimmy P's Avatar
When you start the car, does the idle jump up real high, then slowly goes down? Or does does it only do this when you press the clutch pedal in?
I have a auto trans and when I start the car, the rpm's jump to about 1900 rpm's, then lower down to 950-1000 after about 10-15 seconds. I am thinking it may be because of the large cam in there, but not sure.
