Tacking up slack in the gas pedal
Old Aug 28, 2006 | 01:43 PM
TORCHD 02 TA's Avatar
Default Tacking up slack in the gas pedal
ok i did a search, sort of figured out what everyone was saying. but does any one have any pics of how thye acutally took out the slack??
Another question, before doing the bump stop mod, would you want to take out all the slack first to get a more accurate reading from the mulitmeter? B/C i know that if your under the hood and pull the throttle back it goes to the bump stop, but from the gas pedal it does not touch. That is why i am aking
Old Aug 28, 2006 | 07:46 PM
INMY01TA's Avatar
Does your car have tcs?
Old Aug 29, 2006 | 12:13 AM
jimmyblue's Avatar
Moderator
Do not bump-stop it by the meter, do it by ruler to
dead center. Then verify the voltage is still proper
at closed and WOT.
TCS/ASR cars have three cable runs. Two are
adjustable and one is not. The run from pedal to
pulley cluster has to be fixed the hard way. I
used a piece of vacuum hose, a washer and a
piece of heat-shrink tubing but you could use
other things. Slit the hose lengthwise and the
washer across one side. Slip them over the bare
cable with hose against the pedal and washer
against the ball end on the cable. Slip the
heat-shrink (which is just larger than the vac
hose OD) over the hose, washer and ball. Now
shrink it and you're all caught up. You could
probably get by without the washer but I didn't
want the ball to pull in.
Old Aug 29, 2006 | 08:49 AM
lt1_man's Avatar
How can I take up the slack in a lt1 base car?
-Thanks Brandon
Old Aug 29, 2006 | 09:12 AM
GM Muscle's Avatar
I run a 98 TB in my car and had to take up a good 3/4" of slack. What I did was took some brake line, used a dremel to cut a slit down one side, and then cut it to length. So it basicly slides right over the excess line between the end of the line and the pedal. I used heat shrink for wiring harness' to hold it in place, double shrinked it and it works awesome.
Old Aug 29, 2006 | 01:31 PM
no TCS on my car
Old Aug 29, 2006 | 07:45 PM
KrazyDan's Avatar
how much difference will doing this make. Will it change throttle response and over all power?
Old Aug 29, 2006 | 08:56 PM
bene's Avatar
Trunion King
+1; I did bump stop mod and didn't do a slack. WTH is it?
Old Aug 29, 2006 | 09:07 PM
INMY01TA's Avatar
For TCS cars follow the throttle cable back from the tb till you reach a little "black box" on the cable. This "black box" is two pieces, unclip it. Throttle cable housing itself is two pieces also. After unclipping black box, spread cable housing apart to remove remove slack, pull together to create slack. Snap black box back together. Don't know about non-tcs cars, believe they are different. Takes about 8 seconds.
Old Aug 30, 2006 | 07:38 AM
bene's Avatar
Trunion King
So what does it do?
Old Aug 30, 2006 | 01:35 PM
yea i need to do that to my car the bump stop mod. LIKE NOW.. and i will figure out how to take the slack out too
Old Aug 30, 2006 | 02:03 PM
jimmyblue's Avatar
Moderator
Bumpstop makes it so the blade -can- open fully.
Slack may need to be taken out, to make it so it
-will- with the pedal. Even if you get the adjustable
runs snug you may or may not have enough draw
length minus slack in the pedal run (on a TCS car)
to do it. This is where the spacer comes in.
Old Aug 30, 2006 | 02:13 PM
knight rider WS6's Avatar
and if you don't have tcs any way to fix the slack? With no slack will I see improvements?
Old Aug 30, 2006 | 04:46 PM
bene's Avatar
Trunion King
Soo you would only do this "if" you have a slack after TB bump mod. In my case, I don't have a slack at all.
