Oil in the intake...
Old Aug 30, 2006 | 06:24 PM
DEEZ98Z's Avatar
Default Oil in the intake...
I pulled my intake apart to get it ported... when I opened it up there was quite a bite of oil in there I have heard using a catch can helps but I have also heard that they can cause the seals to pop out due to too much pressure What can I do to help this???
FYI - My valve covers are off of a truck (only one pcv on one side) and my baffles have been removed for clearance.
Old Aug 30, 2006 | 08:09 PM
jimmyblue's Avatar
Moderator
If you have seal-popping pressure levels you don't
have a PCV problem, you have a blowby problem.
PCV is orificed down so it only can draw a little flow.
Idle, low cylinder pressure, low blowby, fine. WOT,
fuggedaboudit.
Old Aug 31, 2006 | 06:02 AM
DEEZ98Z's Avatar
I did some more searching... and I think am going to switch to the ls6 valley cover/ PCV system and put in a catch can. If I go to the ls6 style pcv... should I pull my old pcv system off or use it as extra?
Old Aug 31, 2006 | 07:07 PM
INMY01TA's Avatar
I've got the LS6 valley cover too. Cap the fittings on the valve covers and hook the catch can right up to the LS6 valley cover. (like this)
Old Aug 31, 2006 | 08:55 PM
DEEZ98Z's Avatar
Where did you get that catch can and how much was it?
Old Aug 31, 2006 | 08:58 PM
INMY01TA's Avatar
I paid $50 for it from some guy sellin em on LS1.com about 3 or 4 years ago.
Old Aug 31, 2006 | 11:42 PM
parbreak's Avatar
I was under the impression the whole idea behind doing the LS6 conversion was so you wouldn't need a catch can. Just put in the valley cover, seal the valve covers and that's it.
Bryan
Old Sep 1, 2006 | 10:29 AM
sickws698's Avatar
I think u stil need it...not sure
Old Sep 1, 2006 | 03:58 PM
INMY01TA's Avatar
I got just as much oil in the intake after the LS6 valley as before. Most useless mod I ever did.
Old Sep 1, 2006 | 07:42 PM
The PAT WS6's Avatar
i would deff. recomment going with a catch can u can find a good write up on here if u look around hard enough
Old Sep 1, 2006 | 09:29 PM
SIC LSX's Avatar
i did a catch can and i got rid of ALL of it
Old Sep 2, 2006 | 02:44 AM
catch can all the way mine has picked up quite a bit of oil for the month ive used it already
Old Sep 2, 2006 | 09:46 PM
DEEZ98Z's Avatar
I ordered the ls6 valley cover and will be going to Home Depot to get a catch can... thanks for the input.
