A/C delete ?
Old Oct 9, 2006 | 04:50 PM
K9 Pusher's Avatar
Default A/C delete ?
Does anybody have a writeup for the proper way to take the AC out of the car? I'm sure it is pretty simple but I don't want to go ripping parts out vicariously. I would like to do it properly so I can put it back in if I chose later on down the road. Thanks for any help.
Old Oct 10, 2006 | 01:57 AM
Shallow Bay's Avatar
TTT... I'm also looking at doing this.
Old Oct 10, 2006 | 02:23 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Are you talking total removal? Or just under the hood?
Old Oct 10, 2006 | 02:45 AM
parbreak's Avatar
It is really VERY simple and does involve some vicarious ripping out of parts!!
Unbolt the pump on the passenger side of the block and quite honestly pull out everything connected to that. You should have the pump and bracket, the dryer(accumalator) and the condensor(next to the radiator) and all hoses that connect them. Tape off the connector going to the pump and wire tie it out of the way and that's pretty much it.
Bryan
Old Oct 10, 2006 | 03:16 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
You end up with a good sized box full of parts.
Old Oct 10, 2006 | 05:25 AM
K9 Pusher's Avatar
Sounds simple enough, I am doing this as soon as I get my car back from getting the hardtop replaced. Thanks for the help.
Old Oct 10, 2006 | 05:34 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
What happened to the hardtop?
Old Oct 10, 2006 | 10:14 AM
parbreak's Avatar
Box full of parts should look something like this:
Old Oct 10, 2006 | 02:58 PM
okls1's Avatar
Can the a/c be reinstalled with no problems? What is needed to make it work agian? I am thinking about taking mine out because I never use it and its winter, so save a little weight. Thanks
Old Oct 10, 2006 | 05:07 PM
K9 Pusher's Avatar
The paint has the pimples that plague our cars and GM agreed to take care of it. I should have it back by Friday...
Old Oct 11, 2006 | 02:25 PM
K9 Pusher's Avatar
What is involved with discharging the system? How would one go about doing this? I'm gonna be babysitting the wife for the next couple of days (she is having surgery) so I figured I would start working on the car some while she is sleeping.
Old Oct 11, 2006 | 02:53 PM
parbreak's Avatar
Real easy, unscrew the plastic cap on the accumulator(dryer) and press in the little Scraeder valve to relieve the pressure. Then start disassembly. The accumlator is the large aluminum piece that is octagonal in shape.
Old Oct 11, 2006 | 04:37 PM
K9 Pusher's Avatar
On another board I was told that when you run your defroster it will kick a SES light, is this a true statement? Is there anyway to have this tuned out? Sorry for all the questions, just trying to cover all the bases.
Old Oct 11, 2006 | 11:36 PM
parbreak's Avatar
Stay on THIS board!! No it will not kick any SES lights by removing the AC.
Old Oct 12, 2006 | 05:15 AM
K9 Pusher's Avatar
Haha, I pretty much do. Thanks for all your help Parbreak!
Old Oct 12, 2006 | 12:00 PM
okls1's Avatar
will the ac still work if you reinstall it? Just add the freon right? Im going to take mine out as long as I can put it back on if needed. Thanks
Old Oct 12, 2006 | 12:08 PM
losiguy's Avatar
Yes and Yes.
To take it out just follow the lines, rip basically everything out that is attatched. Took me about 2 hours to do it clean.
Old Oct 12, 2006 | 12:13 PM
SEB's Avatar
SEB
Is there any HP that you really gain by reamoving the AC? Or just weight & how much weight?
Old Oct 12, 2006 | 12:53 PM
okls1's Avatar
Ok thanks. I dont think you gain any hp really just about 40lbs out of the engine bay, and looks better too. Then I guess I should block off whatever is not removed right? Block off plates or what? Thanks for the help, its comin out next week.
Old Oct 12, 2006 | 01:18 PM
phoenix305's Avatar
you might want to take it to someone to take the freon out for you. i guess you could just push on the shradder valve but freon, is toxic. not to mention the effects on the atmosphere. but what ever floats your boat.
