SLP dual/dual hurting my performance?
Just as it states is the SLP d/d catback hurting my hp?
Have a big cam, wanting to play in the upper RPM range is my exhaust restrictive? 2.5 collectors, 2.5 catted Y (dynatech hi flow cats) SLP D/D 3" catback. What flows best?
Could I get away with a Loudmouth 2 given my catted Y without being to loud or drone
As far as the SLP D/D catback, I have always heard it is one of the best flowing catbacks out there. It is a quiet catback but does sound good at WOT and helps with drone sound if you have an ORY.
Question....Im moving to a TD system and am planning on using a Dunomax muffler to replace my existing Dual-Dual..but I d love to keep my Dual-Dual (the sound is great)...would it be too restrictive to "Y" the pipes into the muffler or is it possiable to add a second port to the dual-dual
What kind of system is the SLP Dual-Dual?? I know they don't make it anymore, but I'm just curious what the setup is. Does it have a Y-pipe, or is it a true dual setup from the manifolds back??
It flows just fine. Quiet when you want it to be, sounds great at WOT.
Mine also blew out all the ceramic packing and started droning badly. I actually had two blow out before moving to another brand. My QTEC was worth 8rwhp over it cam only.
That's what she said...
Dual/dual is not holding you back, and your 2.5" y-pipe probably isn't either.
I have a big cam and SLP dual/dual with a cutout in my 4" I pipe. I ran back to back at the track, one open and one closed. There was no difference besides the loud *** noise coming from the car.
