is there a y pipe available for stock manifolds
![Question](https://ls1tech.com/forums/images/icons/icon5.gif)
My friend just got a 98 Z. He was wanting a y pipe with out cats that hook up to the stock manifolds to get a few extra horses with out spending too much. Does anyone know of a company that makes these? thanks.
SLP makes a direct bolt on aftermarket Y-pipe.
Speed Inc is one of the vendors that sells it, heres a link, just scroll down the page:
http://www.ls1speed.com/catagory.cfm?catagory=Exhaust
the slp y-pipe does not delete the cats, if you want to delete cats as well, you need cat bypass pipes from mufflex or a y pipe from stainless works. slp's retains the cats
Worth up to 10 HP per SLP http://www.slponline.com/view_product.asp?P=31035 :
Y-Pipe, Larger Diameter 2000-02 LS1 Camaro/Firebird Replacement
SLP's Y-pipe assembly is available for 1998-2002 Camaro/Firebird with V8 engines. Manufactured from 2-1/2" O.D., 304 SS tubing, it is mandrel bent for smooth, clean bends with superior flow characteristics. This Y-pipe assembly is designed to replace the "flat" factory pipe (behind the stock catalytic converters) and bolt to your stock exhaust manifolds. The free flow bends will increase the efficiency of your exhaust system and make up to 10 additional horsepower depending on the application. This assembly comes complete with installation hardware and instructions.
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
I would doubt the SLP piece would make much, if any, difference. MAC used to make a replacement y-pipe that you could order with or without cats. It bolted directly to the stock manifolds, but was something like $500.
For that price, you could get a set of Edelbrock headers.
JC
JC
JC
JC
no no.. its not $500.... the MAC Y pipe without cats is $185 from www.ws6store.com
the catted version is $350
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
![Talking](https://ls1tech.com/forums/images/icons/icon10.gif)
Originally Posted by 3800RS
buy my stock y-pipe in the forsale section and just weld in some straight pipe where the cats used to be.
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
I have a Stainless Works Off Road y-pipe for 2000-2002 cars that bolts directly to the stock manifolds for sale if anyone is interested, just took it off the car cause I finally got around to putting longtubes on!!!
